New MikesXS coils
  • oldnortonrider
    • 448
    • Fayetteville, ARkansas 72701
    New MikesXS coils
    TopCat; I've a question about the installation. I'm lookin' at your pictorial~~and see that the coil(s)' two primary wire attachments show one: "+" , and one: "-" (one positive and one negative). I haven't looked at the old coils to see if they have the same indication (I'm guessing that they don't). If they do, then my question is answered; if they don't, the question: (?) which of the two color coded primary wires go to the plus or minus? Or does it matter? I have two schematics~~one in color~~they're no help at all.
    Coils on the way from MikesXS, as of two hours ago. And I've got two partial boxes of the yellow 8mm Accel wires, that I've had for some years, that I'd gotten for my '78 - 454 - Suburban, that I bought in '77, that I still have.
    JCarltonRiggs
  • John
    • 5117
    The postive wire will connect to the red/white wire, it comes from the TCI, and the negatives will connect to the gray and the orange wire. Those two lead to the P/U coils.
    • oldnortonrider
      • 448
      John; much thanks. Appreciate the info.
      JCarltonRiggs
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        Mikes XS coils
        Just installed MikesXS coils on my XJ . Took about 3 hours of leasurely work . I added covered solderless connectors instead of the ones sent . I used vaseline instead of copper conductive grease on each end of each secondary wire and a bit on each primary connection. I sealed the coil caps with some black RTV and all other connections with di-electric grease . Spark plug caps are new from last year . Had to toss the trim bracket (wasnt in use)
        Bikes starts better . Runs better . I think the gas mileage is better . Its all good for about $75 .
        My old coils were still ok and I may try the wire replacement mods in the future . It was the wires that were breaking down after 25 years . Imagine !!
        XJ1100K
        Avon rubber
        MikesXS black coils
        Iridium plugs w/ 1k caps
        MikesXS front master
        Loud Horns (Stebel/Fiamm)
        Progressive fork springs
        CIBIE headlight reflector
        YICS Eliminator
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          i will do this swap soon as well... the only thing i am wondering about is i had a camaro that i used the universal 7mm accell yellow wires on and it ran a little funny for a while and i noticed one night with the hood up i was getting purple discharge from the wires hitting the manifold! so i went to 8mm wires from accell with no problems. i also had a msd 2 blastercoil i think it put out 45,000 volts??? so would 7mm be ok for the mikes coils or should they be 8mm?
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          mikes650 front fender
          led's gallore...
          renthal bars
          gold valve emulators
          vmax tensioner
          Rifle fairing
          • oldnortonrider
            • 448
            Yep; mine starts better, too. Have 71 miles on it since the change; haven't filled up to check, yet. Had gotten 23-26 mpg before. Seems to run along at 50-55 with less throttle, and does have better "throttle response". Yeah, it does have a bit better power.
            My old coils were oil damp, about half way up the sides~~front and back and side(s) of each coil. (not engine oil). Not saturated, not dripping~~but, yes, discolored with "oil dampness appearance". (?) Coil secondary wires were in bad shape.
            And~~you'll note~~on earlier posts of this thread, PO had replaced the RH coil with a 1.5ohm coil; still running the original 3.0ohm on LH~~no ballast resistor. And, earlier this year (I had made mention on another thread), I had discovered that PO had converted the 4R0 tci box to 2H7 box and had changed the pickup coil plate that would have the 2H7 advance behind it.
            JCarltonRiggs
            • oldnortonrider
              • 448
              Correction~~info I had discussed, about running two different coils on this machine for all these years~~on a different thread~~
              JCarltonRiggs
              • PalmSpringsXS
                • Jun 2008
                • 15
                • Palm Springs
                Where can I get a set of these coils and how much do they run?
                • thewiz
                  • Oct 2006
                  • 1115
                  • Wilksboro, NC
                  Get yer High output ...
                  coils here
                  Part #17-6803
                  80G Mini-bagger
                  Past XS11s
                  • PalmSpringsXS
                    • Jun 2008
                    • 15
                    • Palm Springs
                    I have a xs1100 SF..
                    do these plug and play, or would I need to fabricate a bracket? I read here that you need 7mm plug wires and caps and can omit the crappy frame mounted resistor.
                    • Crazcnuk
                      • Aug 2006
                      • 2980
                      • Hinton, AB, Canada
                      Mine bolted right to the stock mounts. They are 90deg rotated, but this caused no issues.
                      Took me about 20 minutes to install them.
                      I have an 80 standard.
                      '05 ST1300
                      • Axel
                        • May 2007
                        • 869
                        • Renfrew,Ontario
                        details
                        Mine mounted the same as stock with the omission of the black plastic trim (guard ) bracket . You can use 8mm or 7mm wires . On 78 to 80 you omit the resistor . 81 and up doesnt use one .
                        2 coils are $64 in MikesXS.com site . That included shipping for me From Florida to Ontario , Canada with no duty charges (USPS).
                        XJ1100K
                        Avon rubber
                        MikesXS black coils
                        YICS Eliminator
                        • melbxs
                          • Jul 2008
                          • 58
                          I too have new coils (Dynas) and would be interested to know if people thought that their bikes were running OK prior to installing new coils and what they thought after.
                          I. personally, thought my bike was going reasonably well. After the new coils I was blown away by how much better it was.
                          I am sure there are heaps of owners who are missing out on the most effective mod of them all.
                          Be nice to hear others before and after experiences.
                          Melbourne, Australia. XS1100RH
                          • Axel
                            • May 2007
                            • 869
                            • Renfrew,Ontario
                            Comments
                            I had an improvement for sure but less than I thought I would get . To qualify , for a quick job I used 7mm wire and re-used the resistor caps but I wanted to get a set of 8mm copper core with normal 90 degree conectors . At this point I have resistor plugs and may not have the full effect .
                            This said , I have better throttle response , better starting and improved gas mileage . I think my original coils were quite ok but I had some spark plug wire deterioration and had to often adress that ( cutting shorter ).
                            My bike is running well . Regular color-tuning and synching(Morgan) has raised the bar and theres only so much the coils can do.
                            Through this site I have been able to achieve new levels of tuning perfection all the time . Its been great .
                            XJ1100K
                            Avon rubber
                            MikesXS black coils
                            YICS Eliminator
                            • oldnortonrider
                              • 448
                              Originally posted by melbxs
                              ".............. who are missing out on the most effective mod of them all.
                              Close. and dang sure ain't plug an' play if it's done proper.
                              THE MOSTEST NUMERO UNO EFFECTIVE mod of them all is the TKat Fork Brace! Number one! #1! ........and, it really is plug and play.
                              When I see a spit-shined, spit-polished, modded up XS11 that's obviously had some money and time put into it~~first thing I look at is the forks. If there's no fork brace (preferably the TKat job) there~~what does that tell me about the owner!? duhhhhhhhhhhhhhhhhh
                              Both of the above mods are so important, that after they're done, the rider will actually be excited at the results.
                              JCarltonRiggs
