Cylinder Head Swap?
  • Shuriken
    • 1093
    • Southwest USA
    Cylinder Head Swap?
    Are the 1978 and 1980 (standard) cylinder heads interchangeable?
    Ben
    Formerly:
    1982 XS650
    1980 XS1100g
    1979 XS1100sf
    1978 XS1100e donor
    Re: Cylinder Head Swap?
    I believe that there is a difference in the intake valve/seat diameter.
    Ben
    • Shuriken
      • 1093
      • Southwest USA
      So that would create piston clearance problems (?) and the answer would be "not interchangeable" then, right?
      Ben
      Formerly:
      1982 XS650
      1980 XS1100g
      1979 XS1100sf
      1978 XS1100e donor
        The valves certainly are not interchangable from head to head. I would be inclined to try the complete head though, Ben. Take caution as I have not done it. Has anyone out there done it?
        Ben
        • sixtysix
          No XS but XSive as can be!
          • 1958
          • Central New York State
          I know they changed some stuff on the cylinder head for 1980, valve size was changed, combustion chamber shape. I think the 80 got bigger valves to try and make up for the HP lost due to other emissions regs. Like the non-adjustable vac advance. I am not sure they would interchange.
          Gary Granger
          • Shuriken
            • 1093
            • Southwest USA
            The reason I am inquiring is because I have a 1978 for parts. It has a good set of carbs I cleaned recently and good guages. If not much else I need is interchangeable I'll get rid of the partzer.
            Ben
            Formerly:
            1982 XS650
            1980 XS1100g
            1979 XS1100sf
            1978 XS1100e donor
            • fusionking
              • Feb 2003
              • 453
              • lake of the ozarks MO
              Of course they will interchange! Just swap out ever else it takes like pistons etc... Sounds Like more power could be on tap though. Older heads (smaller chambers) newer valves (bigger) newer pistons or big bore which would already have bigger valve notches. You can bet this has already been done. Garry
              Garry
              '79 SF "Battle Cat"
              outbackweld@charter.net
              • Shuriken
                • 1093
                • Southwest USA
                Thanks for the replies everyone.
                So.... I use my existing 1980g cylinder assembly. I bore it to fit the Wiseco kit. Install the new pistons. Use of the '78 head is okay because it has smaller valve dimensions and won't interfere with the new pistons, which already give more valve clearance?
                Correct or not?
                Would the reduction in power due to use of the '78 head be enough to justify just rebuilding the '80 head instead and using it? I'm power hungry and want this bike to get the 95hp back and be able to run as fast as I've heard they can.
                On a different note, I also went through the carbs that came off of the '78. Would there be any performance difference between different years of carb banks?
                Ben
                Formerly:
                1982 XS650
                1980 XS1100g
                1979 XS1100sf
                1978 XS1100e donor
                • Dennyz
                  • 1151
                  • Olympia, Washington
                  My experience has been that '78-'79 carbs are easier to tune for performance over the '80-'81. That said, both sets of carbs can be dialed in to do what they were designed to do.
                  The '80-'81 set has emission considerations that the '78-'79 set does not.
                  DZ
                  Vyger, 'F'
                  "The Special", 'SF'
                  '08 FJR1300
