middle drive
  • red bandit
    • 955
    • central michigan
    middle drive
    How hot/warm does your middle drive get at hiway speeds? After running at 60 plus you can't keep you hand on it for more then a few seconds. Is this normal? Seems a little warm to me???
    Oil is full and clean, 80/90.
    79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
    79 SF parts bike.
    Well... you figure the motor oil is well over 200 degrees, and just the heat transfer from that alone would do that. I was hearing something on my last trip with John and Kat and noticed the same thing. I checked all the fluids again and they were fine... so I went on.
    There are some serious forces being applied in that little middle drive... taking all the HP from your bike and turning it 90 degrees angle-wise has got to get things warm in there. It gives that oil a workout... so that's why you need to change it periodically. Sometimes that oil gets a pretty good stink going to it and smells very burnt. If it's been a while...Feed it some new and go on...
