fj fork
xschop
i have theese three fz600 i used to race
about 60pounds ago i been driving one of them you 400pounds 60 hp 60 degree fork angle so when i finished the xs it at first felt slow and sluggish but after 15mins it felt so good all that twitching is gone you lay a linedown it follows have drumy front tire i should get some proggesive front springsor lose some weight i weigh 270 but it was woth doing
there's no need to weld that adapter in
i just like to weld i'll let you know when i get some radials
as ever billbill haneComment
forks
yes about an inch another reason to go
bussa i got this fork on whim i saw the wheel with crummy tire and rotors for 19.99 on ebay no bids fork tubes for 9.99
and brake calipers 19.00 no bids on anything acof911 hook me up with tripple threes for 16.00 how could i say no to it.
the hardes part was ginding all the abs on my fairing to fit the wider forks the axel is 40% smaller in diameter gos to show how
over built the xs is. but the stock fork is so lite i dodn't think it's usable at all it's probablly not even strong enough for a 500 i think i'll call this one done and start on my other one going bussa and chain drive theres just no reason to go shaft anymore chains and sprockets last forever now it's funny that the new fj is shaft but that bike is so far away from my idea of what a bike should be in my mind the ideal
new bike would be the bandit but it's hard to beleive even heaver than a xs.bill haneComment
xs's handling
the xs just needs modern handling and you're in a whole new category, I agree. My 530 chain is still tight after the first 1200 miles. TRBIG said there is some type of wax that will stay on the chain and not sling off. I will be checking into that. The grease that came on my O-ring chain is nicely splattered right above the shift mechanism part of the case....MDRNF
79F.....Not Stock
80G......Not Stock Either....In the worksComment
It's a new kind of chain lube that LOOKS like a wax and isn't supposed to sling off like that. Hippydave uses it on his 'Bussa chain. I'll try to get a hold of him again and ask what it is. If his bike won't sling it... your Yammy won't! lol. I'm sure it's just something he picked up at a bike shop somewhere...TRBIG said there is some type of wax that will stay on the chain and not sling off
MDRNF
79F.....Not Stock
found it
thanks xs chop i guess i would use round tube if left to my own but the square tube one would look ok when painted and i have bunch 1 inch square tubing and then it's daily driver. time to start the next one
bussa front end chain drive mono in the frame that single sided arm sure looked good in your pics . workman comp is giving me the snail drag my arm bone was sticking through my skin no faking there
thanks again for the link.
MONO swingarm
The Ducati swingarm from the even numbered ending machines, 748, 916 IIRC would mount up and have the monoshock attachment on the top, would save some trouble in the long run......sorry about your exposed bone
MDRNF
79F.....Not Stock
they look good snow,
wat r the diameters of the fork tubes?
do they sit the same height as the oem forks
cheerspete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
fj
they are 1/2 of an inch shorter than the stock xs but they are made to stick through the top camp to mount clipons. i made them 1/4 inch through the top clamp. i always had my xs about 1 inch out of the clamp so after all is said and done it's about 1/2 to3/4 shorter than before. handles feel nice no more twitching all the time you actuelly turn on arough surface
when xschop said he liked r 1 mono shock
i knew i had to try it i'm about as big as xschop and just like he said it was nite and day so when he said the diff the fork made i knew i had to try that too i got the fj fork brakes wheel and tripple clamps for
about 100.$ i knew the fj was a heavey bike then when i measured the fork i thought it would work good.
bill
ps fork diameter is just under 1 1/2 inchbill haneComment
