I just picked up an 81 xs1100sh I'm rebuilding the carbs, There are caps or plugs where the idle mixture screws should be. Can I just drill the caps out and then are there just normal idle screws under them or I'm I going to mess it up when I drill them out.
I thought I would ask before messing them up.
Thanks
Thanks
Should have done a search first. I found my answer there. My bad, Yes they can be removed using a small drill bit and a wood screw.
