cracked cylinder liner
  • Bigleo
    • 93
    • Surrey BC Canada
    I recently installed a 1197 kit into my XS. Two hundred miles after the installation, I happened to look into the #1 cylinder while doing a plugs read. I found what looks like a crack and some severe scuffing on the cylinder wall. The pistons had the correct clearance, and the rings had the Wiseco recommended end gap. The motor was not abused, and showed no signs of over heating. I don't think that it is a wrist pin clip that popped out as the scuffing is not near that area. Has any one else had a problem with the 1197 kits? I'm starting to think that the 1179 kits, leaving a bit more cylinder thickness, might be a better idea. Oh well back to ripping the motor apart again.
    Leo
    1980 XS1100 Special
    1197cc Wiseco kit
    1978 cams
    4 into 1 Jardine with glasspack
    Keihin CR33 mm carbs
    K&N individual pod filters
    TKAT fork brace
  • 79XS11F
    • Jul 2006
    • 3563
    • Ottawa, Ont. Canada
    Improper large ring end gap would ether lead to low compression, high oil consumption or both but should not damage the walls. Improper small ring end gap would lead to uniform excessive wall wear and in worse case seize up. A broken ring could however do the damage you are seeing or perhaps something got in there during the rebuild?
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
      The Wiseco pistons do have very brittle rings. I broke one on my initial installation... very easy to do.
