house of kolor hi temp
  • rbmgf7
    • Jun 2008
    • 39
    • Ohio
    i came to the exhaust system of my project and some of it was far too pitted and corroded. i decided to paint the exhaust instead of rechroming it. i had the chrome removed and began working on the prep by sandblasting.
    i want a gloss finish but i know the only way to get gloss black on exhausts is to black chrome it. instead, i came by some house of kolor hi temp on eastwood's site.
    the paint claims it does not need to be baked for curing and leaves a semi gloss finish. it also claims it is resistant up to 1400F. i know HOK's reputation is very good but has anyone personally worked with this stuff? $70 a quart is too steep to experiement with.
    my other option was to use some duplicolor/vht 1200F flat black on the headpipes and possibly 500F gloss black engine enamel on the mufflers. anyone try engine enamel on the muff's with good results?
    thanks
    '79 XS1100F
  • 81xsproject
    • 3185
    • Fortuna, CA
    Some folks have had okay luck with the duplicolor, others have not. $70 is expensive, but it sure would be nice to know if it would work and hold up.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • 03mach1
      • 114
      • Cuba, NY
      I used the Eastwood HI Temp Black $15-20/can, and so far holding up pretty good, no flaking or discoloration.
      I think VHT also makes Hi-temp in various colors too. 1200-1500 degrees.
      Dave
      • danteinien
        • Mar 2008
        • 101
        • Utah
        I used DupliColor Hi Temp with Ceramic from Autozone, Like $8 for the can, so far no fliaking or discoloration, been on there for like 4 months now. I sandblasted the pipes before spraying them
        Sorry, bets pic I could find.
        • rbmgf7
          • Jun 2008
          • 39
          • Ohio
          dant,
          that doesn't look half bad. appears to have a little gloss to it. might try that.
          '79 XS1100F
          • bwilding_2000
            • 50
            • UTAH-SLC
            Hey! We need more pics of those last two bikes! They look awesome! SEND MORE PICS! Dante-is that you? I am the guy who bought your old hard bags!
            • danteinien
              • Mar 2008
              • 101
              • Utah
              It does have a slight gloss to it, I would call it satin
              bw 2000, you have a PM
              • DJinNH
                • Mar 2008
                • 854
                • New Hampshire
                Best I can tell from this photo, it looks pretty darned good to me.
                Don
                currently own;
                1980 Yamaha XS1100 SG
                2009 Yamaha Star Raider
                • danteinien
                  • Mar 2008
                  • 101
                  • Utah
                  Maybe this one more better? Looks about the same
                  When I can, I'll try and get one with good lighting
                  Sorry, Giant Pic!
                  • Toolmaker Tim
                    • 671
                    • South Bend, Indiana
                    Just noticed something
                    My headers have flat metal clamp plate instead of the cast originals. I'm jealous. Time to start looking for replacements! seems like every time I turn around I see something else I need. Ain't it GREAT!
                    Tim
                    1979XS1100SF
                    K&N's and drilled airbox
                    Jardine 4in1
                    Dunlop Elite 3's
                    JBM slide diaphragms
                    142.5 main jets
                    45 pilot jets
                    T.C.'s fusebox & SOFA
                    750/850 FD mod.
                    XV 920 Needle Mod.
                    Venture Cam Chain Tensioner
                    • DavesXS
                      • Jun 2008
                      • 231
                      • Matthews, NC
                      High temp clear on the flat will gloss it up. Thats how I did my jeep and will do the same to mine in a few weeks. And makes them easier to keep looking clean.
                      Edit: And can some one make that huge pic 600x600 so I don't need 2 screens to view?
                      • danteinien
                        • Mar 2008
                        • 101
                        • Utah
                        There you go
