Fork Or How Us Country Folk Say Fawk
  • JOEY
    • Jun 2008
    • 73
    • Hastings,Fl
    How do you know when your front fork is going bad? Does it just stay in one position? And if it is how do you fix it?
    It is better to stay silent and be thought a fool, than to open one’s mouth and remove all doubt.
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    I've never heard of a fork going bad, unless it was bent. I've put seals in some honda forks and they are kinda simple, not sure what could go wrong to make them "bad". Are you having a problem?
    1979 xs1100 Special -
    My Bike:
    [link is broken]
    • JOEY
      • Jun 2008
      • 73
      • Hastings,Fl
      No problems im just trying to get my first motorcycle ready for an everyday driver. I just dont know nothing about motorcycles.
      • olebiker
        • Aug 2007
        • 692
        • Kingston ON
        If you are talking about moving the front wheel from side to side then yes you are looking for a place or places that it kind of hangs up. This happens when the bearings in the steering head are worn. To check keep the front wheel off the ground and slowly move the bars back and forth also get in front of that bike and grab the bottom of the forks and see if you can shake them back and forth. If you can then the bearings are loose and need to be tightened. Do not over tighten then as this is what wears them out ( wheelies also are hard on them). After they are tight check again for binding.
        http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
