Frame Reinforcement
  • 79XS11F
    • Jul 2006
    • 3563
    • Ottawa, Ont. Canada
    Frame Reinforcement
    This morning I cut the templates for the steel that I will need to reinforce the hop-up bike's frame. Any input / suggestions are welcome. I have tried to keep this as simple as possible. I'm guessing that 1/8 inch plate will do the job?
    Here's a pile of photos ....
    Rob
    back / top
    Full top
    Head sides, cable guides will be removed and put on the outside of the plate.
    Swing arm
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
  • snowdog51
    • May 2006
    • 348
    • st. paul ,mn
    brace
    looks good i'm sure you know don't get it too hot
    bill
    bill hane
    • olebiker
      • Aug 2007
      • 692
      • Kingston ON
      My my what are workin on now Rob?
      http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
      • 79XS11F
        • Jul 2006
        • 3563
        Hey olebiker ... this is the frame for the 78 XS1100F hop-up bike with the chain drive kit and many other goodies from 1179 kit to full high performance brakes. It's the frame that will receive the engine I recently finished closing up
        Rob
        1978 XS500E
        1981 Suzuki GS1100
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          I don't know
          How you manage to get anything done at all with such a clean and organized man cave. Got "maid service" there?
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
          • geniusloerts
            • Jul 2007
            • 420
            • fayetteville, Arkansas
            if i had a TIG welder and a bunch of free time and some extra $$ i would make an aluminum XS frame.................light weight, can do the reinforcements.......hmmm
            1979 XS1100 SF "Black Goblin"
            -Pod Filters
            -4-1 pipe
            -larger jets for carbs
            1982 XJ1100 "Black Sheep"
            • 79XS11F
              • Jul 2006
              • 3563
              Re: I don't know
              No maid round here, built in or otherwise. I actually have such a small amount of floor space here that I have no choice but to keep after it. In these photos the other 2 bikes are outside in the lane way.
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • 79XS11F
                • Jul 2006
                • 3563
                A custom alloy frame would be nice in deed but would be way to costly for me on this project. It also would take away from the appearance of the bike being an XS11. I do not want to change the overall appearance too much.
                Rob
                1978 XS500E
                1981 Suzuki GS1100
                • olebiker
                  • Aug 2007
                  • 692
                  • Kingston ON
                  Rob having seen your work I can only imagine that this will be a winner.
                  • thewiz
                    • Oct 2006
                    • 1115
                    • Wilksboro, NC
                    Like 'Olebiker
                    too.
                    80G Mini-bagger
                    Past XS11s
                    • thewiz
                      • Oct 2006
                      • 1115
                      • Wilksboro, NC
                      what I was gonna' say ...
                      was: Like 'Olebiker' I'm a big fan of your projects, Rob. Look forward to watching as this one goes together. Thx for sharing so well.
                      80G Mini-bagger
                      Past XS11s
                      • AlanB
                        • Oct 2006
                        • 705
                        • Scotland
                        Hi XS11SF,
                        Looks good!..... quite similar to the European Sport model. I have just recently picked up a spare frame to do something similar with.
                        I was also going to add an extra tube across the front rails, above the upper front engine mounts and just under the top bend in the headers, and a diagonal between that and the original tube for the lower front mount, to make a "Z" brace structure.
                        I was also hoping to build a similar "Z" in the rear of the engine cradle, with the mount tube at the front of the battery as the lower leg of the "Z".... I won't be using the original airbox. I will probably use a horizontal tube across the top of the swing-arm pivots (front to rear?) where you have plate; not 'cos it will work better, but just 'cos it looks great below the side panels.
                        Are you going to put holes in the head braces to alow for access to the coil mounts, or are the coils moving?
                        Great work Rob!
                        AlanB
                        If it ain't broke, modify it!
                        • 79XS11F
                          • Jul 2006
                          • 3563
                          Originally posted by AlanB
                          Hi XS11SF,
                          Great work Rob!
                          AlanB
                          Hey Allen, I would also use tubing but I have been told but the lad that will do the welding that the pieces must be ZERO tolerance fit to do a proper job. That being said I do not have the equipment here to cut and fit zero tolerance tubing. That's why it is all plate / gussets. I was also going to do more around the engine in areas you are talking about but figure it will not be necessary given that the engine mounts are solid. As for coil mount location it is stock and thats why the cut out for the tank mount point is so big. It also gives access to the raer coil mount bolt and there's a hole big enough for a socket that lines up with the coil forward mount bolt. I am most concerned with the head and swing arm areas but must not interfere with access and wiring placement. I will post some pics once it is all wielded up and painted. I still have some "real" fine adjustments to do to my templates as well.
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            send in the reinforcements
                            Hey rob, don't forget that you will have to notch the lower frame tube to pivot point for your chain clearance, it looks like that one front reinforcement will be in the way. I just used a 3/16 thick plate (1"x4" ) bridged from the edge of the pivot bolt housing to the lower frame tube....Looking good, What color will you paint it?
                            MDRNF
                            79F.....Not Stock
                            • chrisso
                              • Jun 2008
                              • 182
                              • Sydney Australia
                              Rob
                              Gday-theframe looks good to me-will be much stiffer than standard.Im interested in the Chain Drive Conversion-can any one put info or pics up. Im guessing 1179 is max cc without liners?? -Cheers oh & happy Canada Day!
                              80 XS11 Standard Australia
