I am turning 5k rpm at about 60-65 mph. Is this right? Or is my speedo off?
RPMs at MPH
Hey Dave,
Here's a thread about RPM vs. Speed .
Depends on which rear wheel you have, but even with the smaller 16" of the special, that sounds just a tad too high.
I get about 4K at 60, have NOT done the 750 Final Drive mod.
You might also have some clutch slippage issues???
T.C.T. C. Gresham
How nature points out the folly of men! -
Dave - At 5k my standard is doing about 80mph. You sure it's the speedo and not the tach giving you trouble? When it says 65, are you passing cages or are they passing you?I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
Dave - did you check the ends of the speedo cable? Sometimes those square blocks on the end of the cable can get rounded off with resultant slippage of the cable.I think I have a loose screw behind the handlebars.
I think its an after market or non original speedo. Is there a way to calibrate them from the inside?Comment
RPM vs SPEEDO
Ok, first and foremost...Speedos should be left to people who have nothing to lose and fat french guys.
secondly, My standard with NO mods runs 4k even at 60. I check it all the time cuz you never know when the speedo is gonna take a vacation without giving the mandated 2 weeks' advanced notice of intent to vacate. Hope it helps."Rat Rod"
79 XS1100 Standard
87 VMAX cans
Cheap Japanese Tires
Cobalt Blue Rattle Can Paint
Custom Lighting on a Budget
Perry Center Fire Department
Perry Emergency Ambulance
"If we don't do it, who will?"
Some people have one of those days, I have one of those lives...Comment
