what size nut is on the main clutch nut?? im stumped
Nut Nut Nut Nut
27mm
the one that holds the basket on, right?
i just had mine off last saturday.....lol, they can be on there really good.....probably you will need a impact.1979 XS1100 SF "Black Goblin"
-Pod Filters
-4-1 pipe
-larger jets for carbs
1982 XJ1100 "Black Sheep" -
nut
If you don't have an impact gun you can also do as follows:
Put the bike in first gear, press down on the rear brake pedal while removing nut with a socket and breaker bar. This will prevent the shaft from spinning while removing the nut. HTH.2H7 (79) owned since '89
☮Comment
installing nut
Installing is the same. Hold down brake and tighten up with a torque wrench. Getting all your gears and forks in properly is the FUN part.
☮Comment
Is there anything I should know about the dremil fix that wasn't in the forum write up any unexpected things that I will run in to? Is it fairly easy?It is better to stay silent and be thought a fool, than to open one’s mouth and remove all doubt.Comment
