Nut Nut Nut Nut
  • JOEY
    • Jun 2008
    • 73
    • Hastings,Fl
    Nut Nut Nut Nut
    what size nut is on the main clutch nut?? im stumped
    It is better to stay silent and be thought a fool, than to open one’s mouth and remove all doubt.
  • geniusloerts
    • Jul 2007
    • 420
    • fayetteville, Arkansas
    27mm
    the one that holds the basket on, right?
    i just had mine off last saturday.....lol, they can be on there really good.....probably you will need a impact.
    1979 XS1100 SF "Black Goblin"
    -Pod Filters
    -4-1 pipe
    -larger jets for carbs
    1982 XJ1100 "Black Sheep"
    • olebiker
      • Aug 2007
      • 692
      • Kingston ON
      Yep 27MM mine came off with impact went back on with an impact.
      http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
      • JOEY
        • Jun 2008
        • 73
        • Hastings,Fl
        Thanks a million for the quick reply I guess im doing the dremil fix on my 82 xj 1100 it wont stay in 1st gear keeps popping out
          nut
          If you don't have an impact gun you can also do as follows:
          Put the bike in first gear, press down on the rear brake pedal while removing nut with a socket and breaker bar. This will prevent the shaft from spinning while removing the nut. HTH.
          • olebiker
            • Aug 2007
            • 692
            • Kingston ON
            That is true but putting it back on is not so simple.
              installing nut
              Installing is the same. Hold down brake and tighten up with a torque wrench. Getting all your gears and forks in properly is the FUN part.
              • NemisusDM
                • Oct 2006
                • 147
                • Carmel, NY
                Used a torque wrench 27MM socket and sticking a hammer handle between the rear spokes works too....lol Just leave it in 4th. Oh yeah don't forget to flatten the lock washer first.
                1979 XS1100SF "Sakura Natsuhiboshi"
                • JOEY
                  • Jun 2008
                  • 73
                  • Hastings,Fl
                  Is there anything I should know about the dremil fix that wasn't in the forum write up any unexpected things that I will run in to? Is it fairly easy?
