So in an effort to get the rear wheel reinstalled on my project bike so I can reinstall the engine I ran into a big problem. The rear axle will not slide through the rear wheel assembly with out binding. After a lot of messing around and a lot of cursing I've found it to be binding in the brake caliper bracket. The bracket will not sit flush and square on the spacer that sits against the wheel bearing and seal. It's like the spacer is too thick, the rotor does not sit out from the wheel far enough or the rotor diameter is too large. I double checked the bearing to make sure it was seated home in the wheel hub and it is, the snap ring is seated as well. This is the only spacer I can find in my parts bin with the rest of the parts I removed when I disassembled the wheel for paint and polish.
Does any one have a picture of this set up on a 79 standard?
Thanks,
Paul
Thanks,
Paul
