I think i might have found a possible solution to finding a rebuild kit for the XJ1100 front calipers.
I have my leftover front pistons from my '78 cb750F which measured 1.500" in diameter. the XJ's pistons are 1.500" too.
height isn't a big deal as the CB was 1.375" and XJ was 1.440". i noticed the XJ also took the squarish type o-ring seal, so did my CB.
the one on the left is the CB and XJ on the right. don't worry about the dado on the CB piston. it's for the rubber skirt that keeps debris out.
so, i guess i'll be ordering a set of CB750F front caliper rebuild kits and see it the XJ calipers will accept them.
actually, this would be just as easy if someone could measure a XS piston and see if it is the same size.
now i'm stuck on the rear master cylinder rebuild kit. does anyone have a real picture of the kit? i have the schematics but that is not enough. if yamaha didn't do this dang linked braking system, we wouldn't be stuck with a larger M.C. piston. i'm sure there is something put there.
now i know bikebandit sells the kit for $50ish but that's extortion when you can get a front for $20.
