inline filters
    • 2117
    inline filters
    Where is the best place to get small inline filters.I was curious about the overall length in between the lines.What size would you recommend?
  • ross
    • Dec 2006
    • 542
    • see signature...
    cheap fuel filters....
    hey there oldyam80sg...i got mine from the local lawn mower repair store...cost about $4 each.....i got the ones that are about 1" in diameter and sorta shaped like a pancake...but i have heard of others that are smaller in diameter and might work better...no matter what, a fuel filter of any shape are better than none at all....took me most of the first of the year out in the man cave just to get all the rust outta the carbs....yuck......good luck...ross
    rebel devil
    1979 xs 1100f standard
    authenic historical vehicle
    42°36'23.52"N, 82°52'44.78"W
    "I'M IN MY HAPPY PLACE"
    "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
    "if you don't wrench on it, get behind me satan!"
    '96 venture cct.....installed!
    stainless, braided, pvc coated brake lines
    i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
    • TupperJ
      • 23
      I've had good luck with standard auto filters, metal cylinder about two inches long and half inch across. I cross my fuel lines under the tank, to the filters are basically horizontal. Sounds funky maybe, but the filters are available EVERYWHERE and this setup has gotten me across the country twice with no troubles.
      Hope that helps.
      Paul
        • 2117
        Thanks-My Pingels have really nice screens on them so they catch alot of stuff but i had some buildup in the lines.Thanks!I will try a shop by me.
        • mro
          • 4276
          • Hayward, California
          The paper filter type seems to work better than the others.
          mro
            • 2117
            The filters i was looking at today said they can be back flushed to clean.If i get alot of crap in the tank will that disrupt the flow?
            • mro
              • 4276
              Get "see thru" plastic filters.
              I got fancy with the hot rod and put on some $10.00 cleanable glass ones. Looked cool until I broke one, other sits in the top of my tool box as a reminder.
              mro
              • ross
                • Dec 2006
                • 542
                • see signature...
                hey there oldyam80sg.....just one question....is it worth tearing the carbs off and apart for $8 dollars...i think not.....mine are white plastic and if they give me problems, i would just replace them rather than take the chance of putting more cr*p from the tank into the carbs...just my 2 cents....ross
                rebel devil
                • Bigleo
                  • 93
                  • Surrey BC Canada
                  Mikes xs has some nice narrow ones for a cheap price. They are clear so you can see the gas level. Just mounted two on mine, they work great.
                  Leo
                  1980 XS1100 Special
                  1197cc Wiseco kit
                  1978 cams
                  4 into 1 Jardine with glasspack
                  Keihin CR33 mm carbs
                  K&N individual pod filters
                  TKAT fork brace
                  • TADracer
                    • 1417
                    • Kenner, Louisiana USA
                    I use a pair of Russell 40 micron filters that are small but you cannot see through them. The only advantage of seeing into the filter is to see if they are full of junk. The level of fuel in the filter is no matter since they do not have to be full of fuel to operate correctly. The fuel is just passing through so if it is only half full it is still working just fine.
                    Mike Giroir
                    79 XS-1100 Special
                    • thewiz
                      • Oct 2006
                      • 1115
                      • Wilksboro, NC
                      I've used
                      the ones at MikesXS and like the small square size. Especially good for a Special with Octy where space is limited.
                      80G Mini-bagger
                      Past XS11s
                      • Axel
                        • May 2007
                        • 869
                        • Renfrew,Ontario
                        visi-filter
                        I used a coule of these visi-filters from NAPA
                        They are quite small and can actually be squeezed between the airbox boots .
                        XJ1100K
                        Avon rubber
                        MikesXS black coils
                        Iridium plugs w/ 1k caps
                        MikesXS front master
                        Loud Horns (Stebel/Fiamm)
                        Progressive fork springs
                        CIBIE headlight reflector
                        YICS Eliminator
                        • TupperJ
                          • 23
                          I was just in our local Lowes and noticed they have a pretty good selection of small fuel filters for lawn equipment.
                          Might be another source.
                          Paul
                            You will want to be aware that some lawn mower filters may not be able to 'pass enough gas' to satisfy the engine at high speed.
                            • thewiz
                              • Oct 2006
                              • 1115
                              • Wilksboro, NC
                              lawn equipment filters ..
                              I have seen a bunch of these types of small engine filters and besides being small, they also seem to have very small 'IN' and 'OUT" holes in them ... less than that of the XS carbs and fuel supply hose. I wonder if anyone knows if that restriction could have adverse effects at all???
                              80G Mini-bagger
                              Past XS11s
