Locking Tabs
  • blue giant
    • Aug 2007
    • 880
    • Ontario, Canada
    Locking Tabs
    Is the use of the locking tabs on the brake rotor mounting bolts crucial?
    Would blue locktite suffice? I would like to use some polished stainless bolts instead for a cleaner some what custom look and do away with the tabs.
    Thanks,
    Paul
    Paul
    1983 XJ1100 Maxim
    1979 XS1100 Standard
    1980 XS1100 Special
    I'm not a motorcycle mechanic but I play one on the internet.
  • Bigleo
    • 93
    • Surrey BC Canada
    I did away with the locking tabs six years ago. Did not use any locktight, just stainless lockwashers. I checked the bolts a lot for the first couple of months, but never found one to be loose.
    Leo
    1980 XS1100 Special
    1197cc Wiseco kit
    1978 cams
    4 into 1 Jardine with glasspack
    Keihin CR33 mm carbs
    K&N individual pod filters
    TKAT fork brace
    • randy
      • Dec 2003
      • 4521
      Yes, you can. I used stainless allen head bolts with blue locktite, none have come loose 10k miles later.
      • Guy_b_g
        • May 2007
        • 790
        • Beverly Hills, Florida
        I wouldn't run them without locking tabs...chances are you'll be fine without the tabs, but I wouldn't bet my life on it. Especially with locktite...the best way to get a part that's locktited off is with heat..and brakes generate plenty of that.
        Those discs cycle hot & cold all the time, and that can cause the bolts to loosen over time.
        The engineers knew what they were doing when they put the locking tabs on.
        I personally dont use locking tabs, but I have drilled and safety-wired my bolts (same difference...I just like the looks better)
        I once had a nut come loose on a countershaft sprocket on a 750 Kawasaki. I was coasting down a long 6% grade and a truck came up behind me (reason I was coasting is I was almost out of gas)...when I put it in 5th, gassed it and let out the clutch it spun the sprocket off and my chain locked up. Truck barely missed me as I skidded off the road. The locking tab had been overlooked when the bike was assembled and was never bent over.
        I always check and make sure everything that gets a locking tab is secure now..either with the tab or safety wire.
        Guy
        '78E
        • GNEPIG
          • Apr 2005
          • 1656
          • fl
          Custom bolts with safety wire- I like that one.
          If you don't end up using wire, at least use red locktite.
          • blue giant
            • Aug 2007
            • 880
            • Ontario, Canada
            Good point ,the red would offer a little more security.
            Thanks.
            Paul
            1983 XJ1100 Maxim
            1980 XS1100 Special
