XJ running like (*&^
  • #16
    Did a bunch of troubleshooting today. Ruled out the coils, pickups, and all the wires in between so I am back to the TCI. My brother in-law works on small electronics for a living. He is going to see if he can figure out which component is not working.
    Harry
    '79 Standard
    '82 XJ1100
    '84 FJ1100
    Acta Non Verba
    • #17
      spray starter fluid at the carbs to the cylinders not firing.
      Have you pulled the plugs and checked for spark? Insert plug in wire and touch the tip of the plug to the block and turn it over. Keep your fingers as far from the wire end as you can when you do.
      Have you checked continuity in the wires leading to everything?
      • #18
        yes to all of it. Pulled plugs to verify no spark. Checked continuity on all wires. Swapped connections on the coils and got spark so we knew the coil wasn't bad. Swapped connections to the pickups nd had no change in conditions which lead us back to the TCI. . We are gonna disassemble it and check all to the components on the board. This is not something I would normally do myself but my brother in-law does this type of stuff for a living and has the knowledge and tools to do it right. Unfortunately I will have to wait until tuesday for him to be able to do it. On a positive note, I am getting a better understanding of the electrical system on this bike.
        Harry
        '79 Standard
        '82 XJ1100
        '84 FJ1100
        Acta Non Verba
        • #19
          TID14-10
          Everyone should do it at least once .
          http://minneapolis.craigslist.org/mcy/710278740.html
          This is about as expensive as they get .
          XJ1100K
          Avon rubber
          MikesXS black coils
          Iridium plugs w/ 1k caps
          MikesXS front master
          Loud Horns (Stebel/Fiamm)
          Progressive fork springs
          CIBIE headlight reflector
          YICS Eliminator
          • #20
            whole bike + parts bike
            An interesting listing : eBay Item number: 260256072458
            XJ1100K
            Avon rubber
            MikesXS black coils
            YICS Eliminator
            • #21
              TCI
              This is my dream :
              To find this in a barn somewhere
              XJ1100K
              Avon rubber
              MikesXS black coils
              YICS Eliminator
              • #22
                $295, what are they smoking?
                Harry
                '79 Standard
                '82 XJ1100
                '84 FJ1100
                Acta Non Verba
                • #23
                  I think we got it fixed. Took the TCI apart. removed and tested most components on the board. Didn't really find anything wrong. Re-soldered everything back on the board. Put it on the bike and had spark. I need to finish putting the bike back together but I do believe it to be fixed. Thank you to everyone who chimed in to help me troubleshoot this.
                  P.S. If anyone has any "dead" TCI's laying around that they don't want, I will pay shipping to get them. The prices that these are going for on Craigslist and ebay are rediculous.
                  Harry
                  '79 Standard
                  '82 XJ1100
                  '84 FJ1100
                  Acta Non Verba
