Chirp(whirp)
  • CarolynS
    • 369
    • Massachusetts
    True
    You're right, I'm sorry.
    It's just hard to understand what he's trying to say, much less give an answer. Maybe he doesn't even want an answer.
    What does a burned bearing/rod sound like anyway?
    80 XS1100G w/ Windjammer-the Witch
    79 XS1100F
    "Look Ma! No hands!...."
    • geniusloerts
      • Jul 2007
      • 420
      • fayetteville, Arkansas
      dunno,
      Rods,I have never heard one before.....burnt pistons yes. bearings, ones that have seized and spun, yes.
      I once snapped a connecting rod in three on a alcohol burning lawn mower i built in my high school shop class.....bad news...lol
      1979 XS1100 SF "Black Goblin"
      -Pod Filters
      -4-1 pipe
      -larger jets for carbs
      1982 XJ1100 "Black Sheep"
      • egsols
        • Jan 2006
        • 1090
        • Barrie, Ontario, Canada
        I would expect a burned/bearing rod to emit no sound.
        Ernie
          It makes the EXACT sound that hundreds of dollars make!
          What I got to thinking about, is if he knocked out the crank bearings enough to where it's wobbling a bit... the rotor rubbing on the stator (There's not much clearance there) does make that sort of chirping noise...... I'm really sorry that I know these things for a fact.
          • prometheus578
            XS-XJ Super Guru (RESIGNED)
            • Aug 2004
            • 4012
            • Olympia , Wa.
            Bad rod bearings will knock.. thump, actually.
            Easy to find mit der stethoscope.
            Sometimes will knock all the time, sometimes only under load.
            Put the bike on the centerstand and fire it up. Put it in gear and let the rear wheel turn. Slowly apply the rear brake to load the engine. Oh, she'll start knocking then.
            When knocking at idle... pull the plug wires one by one. When the knocking stops, you've found the bad piston/rod.
            Chirping...?
            Lack of lubrication somewhere. Overheated rings... destroyed bearings....
            Of course, chirping sounds a lot like squeaking and hissing... could also be a loose header or a leaking exhaust gasket.
            • Shuriken
              • 1093
              • Southwest USA
              Originally posted by prometheus578
              Chirping...?
              I became troubled when I began hearing an abnormal squeaking/chirping sound from the piston area. Was real worried that I would have to do a rebuild. Then one day out of curiosity, I tightened the exhaust flange bolts. Problem solved. Thank goodness.
              Formerly:
              1982 XS650
              1980 XS1100g
              1979 XS1100sf
              1978 XS1100e donor
              • Shawnb
                • Jun 2008
                • 88
                chirp whirp reply
                i know I don't make a lot of sense not checking for intelligence not sure how much I might have just having problems with my MOTORCYCLE, aplogize to all thanks for your help xs11.
                • Shawnb
                  • Jun 2008
                  • 88
                  hey
                  cruising the sound is on cruising it's normal seems to be what makes this bike and xs.
                  • olebiker
                    • Aug 2007
                    • 692
                    • Kingston ON
                    Sorry I still don't have a clue what you are talking about.
                    http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
                    • GNEPIG
                      • Apr 2005
                      • 1657
                      • fl
                      Me neither.
                      • renegade_xs11g
                        • 462
                        • Mid-Michigan
                        Re: chirp whirp reply
                        Giberish, That's what that is.....
                        Funny thing....I understand giberish...
                        It would seem that you believe the XS may need oil mixed in the gas, not sure if you mean in the engine or in the tank....both are false
                        also....
                        chirping, or whirping as you describe it no matters where it comes from, isn't normal...and there is a reason for it
                        you say its while cruising....yet give no details on speed, rpm, what gear
                        really need more info....even a translator would help....
                        My Photo Bucket
                          • 5062
                          Re: hey
                          A little more puncuation and a proof-read before hittimg "send" will go a long way my friend! I have the same problem myself!
                          • proctor1
                            • 41
                            • Metro Detroit are MI
                            I just finished reading all of the responses to this thread and I'm still wiping the tears of laughter off of my keyboard
                            Lead, follow or get out of the way!
                            79XS11 Special
                              LOL... Great advice! Classic.. lol.
                              • FSCGunslinger
                                • 200
                                • Hedgesville, WV
                                I was wondering if anyone else caught that!
                                "I said I never had much use for [a pistol], never said I didn't know how to use one."
                                '82 Maxim XJ1100J (Maroon) - "Organ Donor" - Parts bike
                                '82 Maxim XJ1100J (Black) - "Outrider" - Dynojet Stage 1 kit, Kerker 4-1 exhaust, AGM battery, Mikes XS coils, small inline fuel filters, Dunlopp Elite-3 tires
                                '06 Star Warrior (Custom Gadsden Flag Theme) - "ΜΟΛΩΝ ΛΑΒΕ" - Sissy bar w/ luggage rack, 4" risers, braided stainless steel cables and brake line; Mods on deck: new exhaust, new seat
