tach and headlight problem
  • tjhummer
    • Jul 2006
    • 55
    • Pittsfield, PA
    Hi all, I have been lurking for days looking over all the posts regarding headlight and tach problems. My headlight and tach quit working at the same time, but for only a few seconds. (This is a problem at night on curves.) I have replaced the old fuse holders and fuses, checked the alternator connectors (clean and dielectric grease) behind the fuse panel, checked for charge voltage (14.6v), still have problem. What I am looking for now is where the connections are where the headlight relay and tach signal tap into the alternator winding. I don't want to disassemble more than I have to getting at the right spot.
    80G XScitant XStreme
    "Don't ever give up, don't ever give in, and don't ever read the owner's manual."
    -- Red Green
    Bikes I have owned --
    '68 Honda 90
    '74 Yamaha Enduro 125
    '75 Husqvarna 250CR
    '85 Kawasaki KLR250
    '80 Kawasaki KZ750H1 LTD
  • tarzan
    • 1700
    • Chandler,Az.
    Under the gas tank is the regulator.Check connectors and grounds.I f you have tach and lights sometimes it is probably a
    connection of some kind.If no tach or lights at all it is probably the regulator.
    80 SG XS1100
    14 Victory Cross Country
    • tjhummer
      • Jul 2006
      • 55
      • Pittsfield, PA
      I have headlight and tach most of the time. They just cut out for a couple of seconds here and there. No problem during the day, but at night out on winding roads, it's kind of hairy. Thanks for the reply.
      -- Red Green
      '68 Honda 90
      '75 Husqvarna 250CR
      '85 Kawasaki KLR250
      • GNEPIG
        • Apr 2005
        • 1657
        • fl
        Sounds like the reserve lighting device has a loose connection or is about to take a poop.
        This part is a square black box located under the fuel tank.
