Side Battery Cover Strap Wire???
  • NemisusDM
    • Oct 2006
    • 147
    • Carmel, NY
    Hello,
    I'm just trying to figure out what this is....? I have never seen it before....
    "Side Battery Cover Strap Wire
    New Yamaha side cover attaching wire for 1978 - 1980 XS1100 models. OEM p/n 2H7-2814A-00-00."
    1979 XS1100SF "Sakura Natsuhiboshi"
  • XSrunner
    • Feb 2008
    • 97
    • Batemans Bay AUSTRALIA
    that is the tool to hold up the drive shaft when you take the back wheel off.
    JOHN'O
    Xs1100E 1978
    American Import Cruiser
    • egsols
      • Jan 2006
      • 1090
      • Barrie, Ontario, Canada
      On the Standards the exhaust came back farther and you couldn't access the axle unless you held up the swingarm. The wire would do that for you. On the specials the exhaust didn't interfere with the axle so they didn't need it.
      Ernie
        • 5055
        It also came with a special lever to fulcrum the wire, compressing the shocks, allowing you to hook it on the trailing arm.
        • NemisusDM
          • Oct 2006
          • 147
          • Carmel, NY
          Thanks for the info guys..... I thought it was a scam at first but, I have the Special which is probably why I never heard of it... lol
            • 5055
            You would know if you needed it the first time you tried to pull out your rear axle.
            • XSPastor
              • Oct 2007
              • 602
              • Gaithersburg, MD
              There's one of those for sale on ebay right now...
              Tim Ripley - Gaithersburg, MD
              23mm float height
              120 main jets
              42.5 pilot jets
              drilled stock airbox with K&N
              Jardine 4 to 1 Exhaust
              spade fusebox
              1st and 2nd gear fix
