Coil upgrade caps
  • Bamper
    • 97
    • Maine
    Coil upgrade caps
    Once I sell my saddle bags I'm going to get the coils from mikexs and from what I gather they need to be the 17-6803 P/N the ones that are 3ohm. So my next question is does it matter the resistance on the plug caps because he sells 5kohm and 1kohm caps. Also under the same section as the coils it has NGK plugs and it claims a 2hp gain so my question is what one of those will fit a 79XS1100 SF if any? One last question if I get those coils can I take the ballast resitor out?
    Thanks in advance.
    Chris
    1979 XS1100 SF (production number 572)
    1972 Kawasaki g4 TR-B with high and low transmision
    1974 kawasaki G4
    2003 Polaris 250 Trailblazer
    1975 Yamaha Enduro 175
    • 8962
    coils + caps
    Coils, 17-6803, correct.
    Caps, 23-3113 5kohm, correct, but cyls 2+3 usually use a longer plug cap, but these will work.
    Plugs, the BPR7EIX are 1 heat range colder than recommended for our engines, plus they are resistor plugs, which you don't need unless you have some kind of radio on your bike. If you want NGK irdium plugs without resistor, I believe the correct # would be BP6EIX, auto parts store might have them. The number for the regular plug is BP6ES.
    • Bamper
      • 97
      • Maine
      K thanks I'll just stick wtih the stock ones for now.
      1974 kawasaki G4
