80mph+ vibration
  • geniusloerts
    • Jul 2007
    • 420
    • fayetteville, Arkansas
    80mph+ vibration
    ok so i have some ideas of what maybe would be causing the vibration but wanted to run it by you guys first.
    so at 80mph and up there is a vibration in the front, kinda like hitting alot of big bumps in the road and it is continueous...... my thoughts are the brakes dragging(I have the rebuild kits) or the wheel is un balanced.
    what do you think
    1979 XS1100 SF "Black Goblin"
    -Pod Filters
    -4-1 pipe
    -larger jets for carbs
    1982 XJ1100 "Black Sheep"
    vibration
    I'd bet on unbalanced wheel. Mine did the same, had the wheel balanced, smooth up to 110.
    • geniusloerts
      • Jul 2007
      • 420
      i have been wanting to go up higher but the vibration just keeps me from getting there. the fastest i have gone on it was 100 but i backed off because of the vibration. it has alot left in it
      I will check that out.
      -Pod Filters
      -4-1 pipe
        vibration
        Yeah, I'd think that if the brakes were at fault, it would do it at lower speeds too.
        • Da-Bubble
          • Jun 2006
          • 353
          • Oklahoma City, OK
          I don't know of any roads around here that have speed limits over 70mph anyway....Just SLOW DOWN!!!!!!
          Hehe....I had to play devil's advocate.
          1979 XS11 Special (slightly modified)
          dubbed the "Mad Mosquito"
          MikesXs Pod Filters
          MikesXs 35k Coils
          8mm plug wires
          42.5 Pilots 142.5 Mains
          (Carb tune by GNEPIG Performance)
          Kerker 4-into-1
          Shaved emblems
          Progressive frt springs lowered 1.5"
          Progressive 11.5" rear shocks
          Harley Dyna rear fender chopped
          Custm side mt tag (apparently illegal)
          Custom Dual Headlights
          Lots of time and hard work.
          • geniusloerts
            • Jul 2007
            • 420
            It's not me, The bike does it
            its just so funny to see people look and say what the heck was that.
            -Pod Filters
            -4-1 pipe
            • Bigleo
              • 93
              • Surrey BC Canada
              I had a fairly severe vibration last year. Turned out to be tightness in the rear U joint. It was't loose at all, just was a little tight moving it one way, and normal moving it on the other axis. replaced the U joint with a spare I had, and vibration was gone. I tend to agree with some of the other comments that the wheel could be out of balance. Maybe also a warped brake rotor.
              Leo
              1980 XS1100 Special
              1197cc Wiseco kit
              1978 cams
              4 into 1 Jardine with glasspack
              Keihin CR33 mm carbs
              K&N individual pod filters
              TKAT fork brace
              • Paintman
                • Mar 2008
                • 312
                • rapid City SD
                Speed Limits
                Hey speed limits here are 75 Hi way 65 dirt roads LOL
                John
                <---Never goes fast
                79 XS1100SF 750 FD,Galfer Brake lines,ebc brake pads,Cross Drilled Rotors,TKat fork brace,bead blasted wheels repainted and polished
                80 XS1100 S Project gonna be a hot rod
                06 CBR1000RR sold!!!!!
                2000 Concours
                84 Kawi KLR600
                79 Yam XT500 Ouch it kicks back
                79 XR250
                Why is it that the smallest part can fly to the farthest part of the shop?
                John
                  • 3193
                  I have had a seperated front tire before. It acted a lot like it was out of balance in the early stages. As it got worse it became more pronounced at lower speeds. We were out on a Santa toy run. We were 50 miles from home when it finally kicked in to a full wobble. The tire was looking like it was swaying up front. All the guys stayed with me while we rode about 20 mph to home. I appreciated every one of them (metric and harley riders) staying with me till I was oughta danger. Just a thought that your vibration may be a tire seperating on you. I am sure the Guru's have better Ideas but I would check that possibility as well.
                  • geniusloerts
                    • Jul 2007
                    • 420
                    well, i belive then i will be taking the wheel off and having it balanced and the tire checked out, and while i am at it its time for breaks. if the tire is bad i will do the XJ wheel and rotor swap sooner than later with the caliper rebuilds and the pads. although the guy i bought my bike from said that the front tire was new, but how new i do not know. its the dunlop tire that is ever so popular.
                    -Pod Filters
                    -4-1 pipe
                    • Bamper
                      • 97
                      • Maine
                      Yea sounds like a balance issue. If he changed it himself there is a good posibility that he didn't line the dot on the tire up with the valvestem. The dot dignifies the lightes part on the tire and the part of the rim with the valve stem is heaviest. Or atleast you better hope thats all it is. If it was a sticking/warped rotor then you would think it would just pull that way, not vibrate.
                      Chris
                      1979 XS1100 SF (production number 572)
                      1972 Kawasaki g4 TR-B with high and low transmision
                      1974 kawasaki G4
                      2003 Polaris 250 Trailblazer
                      1975 Yamaha Enduro 175
