Master Cylinder Brake Rear
  • Sandy H
    • Sep 2006
    • 118
    • Toronto Ontario Canada
    In the last 2 months my rear brakes have seized.
    I took it to a bike tech he said he did a flush and a rebuild in the master cylinder.It worked for awhile then it happened again this Sat. before a ride. he did another flush But he recomended That I get another master.It would just happen again.
    I can get another one and put it in.Does any one have any ideas?
    Also in the manual the nozzle that goes up into the cylinder kit does not have a spring attached to the brake arm that attaches to the nozzle that goes to the cylinder kit,mine does.
    the manual does not show any sping at all only on the shaft that goes through the frame.
    I have to add this.The bike sat fot 7 yrs
    Out side of that the bike is great.
    Movin On Down The Line.
    Where Ever You Go.
    There You Are.
    '82'xj1100j Maxim
  • Rhumba
    • 82
    • Vancouver, WA
    Hello,
    I am new to the forum and I'm sure some vets will chime in but by my reading the forum on a regular basis I have found a lot of reference to the "spooge" hole in the master cyclinders (front and rear) that is very small and if overlooked during a rebuild can get clogged and prevent the brakes from releasing. Search "spooge" and I'm sure you will find what your looking for.
    Never scratch your head with a nail gun!
    1982 XJ1100
    • Toolmaker Tim
      • 671
      • South Bend, Indiana
      The gurus on this site have said that sometimes the inside of the brakelines starts breaking down and causes particles to clog up the fluid return holes. I am having the same problem, so I figure I'll have to get new brake lines. As far as the rear M/C goes, mine is from a different bike (Midnite Special). There is a spring on the inside of the M/C and one on the brakelite switch on my 79SF. Good luck!
      1979XS1100SF
      K&N's and drilled airbox
      Jardine 4in1
      Dunlop Elite 3's
      JBM slide diaphragms
      142.5 main jets
      45 pilot jets
      T.C.'s fusebox & SOFA
      750/850 FD mod.
      XV 920 Needle Mod.
      Venture Cam Chain Tensioner
        brake drag
        Might be a stuck caliper too. With the wheel off the ground, if you crack open the bleeder screw and the wheel still binds, then it's a caliper sticking.
          Re: Master Cylinder Brake Rear
          And with the same old, deteriorating brake lines, the new master would plug up also, as would another new master, etc, etc. Good excuse to $pend a few buck$ and install some braided stainless brake lines all around. You'll be rid of the seizing problem on the rear, and you will be amazed by the difference in the front brakes.
          BTDT
