Looking to Buy, Is this good?
  • DavesXS
    • Jun 2008
    • 231
    • Matthews, NC
    Hello,
    I am looking at buying this Xs11 for 850$. He tels me every thing is great but 2nd gear pops out. All other gears are good. Garage kept and started regularly while stored. Says it starts right up. I am 6 hours away and need to be sure this is a good deal. And need to be reletivly sure of the fix as this will be a daily commuter.
    Any help is greatly appreciated.
    Dave
  • Wildkat
    XS Special Gurette
    • Apr 2004
    • 3416
    • Location, Location
    I'd think so...
    if everything else is good on it... looks really nice...
    The 2nd gear is a common problem with these and easily fixed...
    You can find some good info here:
    Dremel Fix
    81 SH Something Special
    79 SF MEAUQABEAUXS
    81SH Nor'eas tah (Old Red)
    80 LG Black Magic
    78 E Standard Practice
    James 3:17
    “Alis Volat Propriis”
    Yamaha XS 1100 Classic
    For those on FB
    • jjwaller
      • Oct 2005
      • 242
      • Gautier, MS
      It's got such a vast number of non-original
      parts that I don't think anything over $500. is worth it.
      John
      Now: '78 XS1100E 750 FD Mod (Big Dog)
      '81 CB900C ( 10 Speed)
      '78 CB750F ( The F)
      '76 CB400F ( The Elf)
      New '82 Honda MB5 Ring Ding
      Then: '76 CB550K
      '78 CB750F
      '84 VF1100S
      And still Looking!
      • DavesXS
        • Jun 2008
        • 231
        • Matthews, NC
        The vast number of non origonal parts are labled as follows,
        1980 Yamaha XS 1100 custom street bike. Custom bobber seat, phantom passenger pad, custom Harley Davidson rear fender, Kawasaki springs, and many other extras. Looks and runs great real head turner! 38k miles and many more to add to it
        I don't see the many extras as a bad thing but quite the opposite. All my toys are modded up.
        • jjwaller
          • Oct 2005
          • 242
          • Gautier, MS
          It boils down to, if you like it, then get it.
          You're the one that has to live with it.
          Have fun.
          John
          '78 CB750F ( The F)
          Then: '76 CB550K
          '78 CB750F
          '84 VF1100S
          And still Looking!
          • DavesXS
            • Jun 2008
            • 231
            • Matthews, NC
            Have fun.
            Well I like the looks (obviously) But the real question was about the 2nd gear thing. So far sounds like a fairly easy thing to fix. But one opinion and one how-to on that so far.
            But the feed back on the 2nd gear thing will determine if I continue to like it and pursue the purchase.
            I am very mechanically inclined. So buy and fix, or seek elsewhere.
            I will get a local mechanics opinion too. But would like more from actual owners.
            Thanks for the input
            Dave
            • red bandit
              • 970
              • central michigan
              The second gear fix is fairly easy, especially if your mechanically inclined and with Ken's step by step instructions. I wouldn't shy away because of it.
              79 SF parts bike.
                • 8893
                tranny
                If you're mechanically inclined, tearing into the tranny of this bike isn't too bad. The gears can be accessed thru the oil pan and splitting the cases is not necessary. You have the option of buying new gears (still available), or re-surfacing your gears. There is also a simple modification you can do while you're in there to prevent 2nd gear from failing prematurely again.
                • DavesXS
                  • Jun 2008
                  • 231
                  • Matthews, NC
                  Re: tranny
                  Thanks,
                  Where are the gears available? New or used?
                  I read the entire dremmel how-to. I would probably get new gears and do the fix to prevent it from happening again.
                  Do you have a link to a site that sells the gears? Or should I just search?
                  Thanks again
                    • 8893
                    yamaha link
                    • Dsxs11
                      • Jun 2007
                      • 240
                      • Millington, Michigan
                      As I recall the gears needed to fix it properly are about 600.00 and the Dremel fix is about 50.00, I did the dremel fix it was easy I would rather do the dremel and get it right then count on Yamaha trying to get it right again.
                      I hate signatures. Too many cars and Bikes to list here.
                        • 8893
                        gears
                        The gears available from Yamaha now are back-cut already, no need to back-cut the new gears. To fix 2nd gear problem you will need 2 gears (countershaft 2nd and 5th).
                        • DavesXS
                          • Jun 2008
                          • 231
                          • Matthews, NC
                          Re: gears
                          Is that # 23 and # 26 on this blow up view?
                          edit: the link did go right to the view. Have to select the bike then transmition to see it
                          80 xs1100
                          • tinman905
                            • Aug 2007
                            • 946
                            • Orangeville,Ontario ,Canada
                            That's a bit steep you can find a better deal sooner or later . Offer him no more than $500.00 . If there was no issuse with the second gear than I would go for it at that price. Just my two cents.
                            I paid just over $400.00 for mine and only had to clean the carbs.
                            BDF Special
                              • 8893
                              gears
                              Yes, #'s 23 & 26.
