can we **** can the octy
  • petejw
    • 2269
    • sydney australia
    I havent run the occy on the bike for years and i never
    turn off my petcocks when the bike is parked, in all that time,
    the carbs have leaked once, no problems, was a broken
    float post. If the carbs leak fix the problem, dont hide it behind closed petcocks. Fix the problem, not the symptom.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • BigDick
      • 521
      • McConnell AFB, KS
      my tank could be special though, had a dip-spit mechanic do some work on my bike a few years back (first and last time that'll happen) and due to things I have found I do not have confidence he reassembled the petcocks correctly. Mine only allow fuel to flow on the reserve position. and for the record I do agree with the sentiment of make sure your carbs aren't leaking and not just hiding it with shutting off your petcocks. I just like the thought of the extra insurance.
      1980 XS11SG
      Dunlop elite 3's, progressive fork springs, tkat brace
      Stock motor, airbox, carbs, exhaust
      ratted out, mean, and nasty
        • 2088
        Enough said.Mine have not leaked since i replaced the float needles or what ever they are called.
        • Cobia
          • Jul 2007
          • 1587
          • Palm Beach County, Fl
          Same experience
          I have the same experience as you Pete. We removed the octy on my '80G and it has never leaked and I don't turn off the petcocks, ever. The '79 came w/out the octy as well as the '82J. And, again, I've never had a leak.
          1980G Standard, Restored
          Kerker 4 - 1
          850 Rear End Mod
          Automatic CCT
          1980GH Special, Restored
          '82 XJ1100 (Sold)
          • Ivan
            • Jul 2008
            • 2524
            • Hutchinson KS
            I fixed my octy. It is just a simple vacuum operated valve and a spring. The seal is a small o ring which had deteriorated and I replaced it. smeared some form a gasket on the edges of the diaphragm and put it back together. Haven't had a lick of trouble with it.
            FWIW, the vacuum petcocks in the Standard tanks are the same thing...
            Ich habe dich nicht gefragt.
