I bought a 1979 xs1100F with full fairing with lowers, trunk, and hard saddle bags, brand new Jardine exhaust not installed, new carb boots not installed, and 3 sets of brake pads not installed. I managed to break of a bolt on one of the intake manifolds. Local machine shop got it out for me though (it was stuck in there worse than I've ever seen a bolt be stuck anywhere)... Cleaned the carbs a little, rigged up a gas tank and away she went...
Carbs leak, need rebuilt or at least new needles/seats, needs seat recovered, needs bags and trunk painted, fairing is near mint and no cracks in the windscreen, wiring is a little buggered, fuse box non-existent...PO soldered the wires together with no fuses whatsoever
, tank needs cleaned and creamed and the bottom of the tank needs painted visible paint when mounted is in very good condition, needs new tires, new fork seals, new front fender (has a few very small rust holes), brakes work very well (thank goodness), took the exhaust off today and one of the bolts was broken off at the head of the bolt (assume PO's doings) no wonder it was smoking on the left side like crazy, the exhaust clamp was completely loose on cylinder 1 because of the bolt, has some tappet rattle (easy fix as long as I don't snap another bolt, a little PB Blaster and an impact driver should do the trick), oil filter housing bolt is rounded off (just going to grind it away and replace it), only has 16,300 miles on it...
I paid.......$350! Muahahaha...Good ole craigslist...actually was looking to get a couple cb750 parts bikes and he just happened to have this too...(didn't get the cb's though, pictures looked a lot better than the bikes did in person)
I need one of the chrome saddle bag brackets that goes around the back of the bag though...
Got it with the fairing, bags, and other body parts dismantled and the wires just cut off from the fairing...except the one black plug...
There are two red wires coming from the left handlebar switch...anyone know where these go? blinkers in the fairing maybe? Also there is a black wire that goes from where the fuse box would be to the front of the bike with a red wire spliced onto it, any ideas what that might be? also a small gauge grey wire at the front of the bike sticking out of the wiring harness under the gas tank to the left?
The bike is the blue colored version btw...
Puttered around the lawn today and it should run great once I adjust the valves, put the new exhaust on, and rebuild the carbs.
Also, one of the tee's on the carbs for the fuel is leaking that goes between 3 and 4...can I get this part new?
Thinking about doing the 750 FD mod...not sure yet though as I don't know how much freeway cruising I'll be doing.
Anyways, any hints/tips on making sure this thing is tip top mechanically would be appreciated...can't wait to tear around on this beast...
Thanks,
-Chris-
, tank needs cleaned and creamed and the bottom of the tank needs painted visible paint when mounted is in very good condition, needs new tires, new fork seals, new front fender (has a few very small rust holes), brakes work very well (thank goodness), took the exhaust off today and one of the bolts was broken off at the head of the bolt (assume PO's doings) no wonder it was smoking on the left side like crazy, the exhaust clamp was completely loose on cylinder 1 because of the bolt, has some tappet rattle (easy fix as long as I don't snap another bolt, a little PB Blaster and an impact driver should do the trick), oil filter housing bolt is rounded off (just going to grind it away and replace it), only has 16,300 miles on it...I paid.......$350! Muahahaha...Good ole craigslist...actually was looking to get a couple cb750 parts bikes and he just happened to have this too...(didn't get the cb's though, pictures looked a lot better than the bikes did in person)
Thanks,
-Chris-
