Stuck Speedometer Repair Pictures
    My 1980 XS1100G Standard speedometer was sticky and the needle was broken so I had to fix it.
    I found a broken 1978 XS1100E instrument cluster in the junkyard but I repaired the 85 mph speedometer first for practice and photographs
    Disassembly:
    Faceplate Removed
    I managed to save the speedometer gasket
    I broke the turn signal self-cancel reed switch
    Mark the speedometer driven wheel and fixed housing before you remove the needle
    Look for grease between wheels and the housing
    Grease buildup between the wheels and the housing caused this speedometer to stick
    Check the spring for grease or dirt
    I have to thank TopCatGR58 for this special speedometer needle removal tool
    Disassemble the faceplate to clean it
    Lightly grease all odometer gears
    Assembly:
    Put the speedometer back in the housing
    Put on the faceplate
    Re-crimp the faceplate retainer ring
    Install the odometer trip reset knob
    Install the turn signal cancel reed switch
    Replace the gasket and put thespeedometer in the bucket
    Put the Speedometer back in the instrument cluster
    The instrument cluster is back on the bike and I have a working speedometer!
    Regards,
    Scott
    Well done Scott. Could you possible expand a bit on the early stages of this - i.e your technique for getting the case "uncrimped" for the repair?
      No problem, Ken.
      I had to re-shoot everything with a regular digital camera so I lost some details.
      For some peculiar reason the original shots I made with my mobile phone camera looked really good on the phone's display but...
      I'll try to get the detail for the faceplate ring and trip reset knob removal tomorrow. The reset knob was actually more difficult to remove than the faceplate.
      Regards,
      Scott
        Speedometer Disassembly
        Disassembly:
        Remove the speedometer from the bucket
        Faceplate Removal
        Use a small screwdriver or other suitable implement to uncrimp the corners of the faceplate
        Pry the middle edges away from the speedometer housing
        Gently lever the faceplate off of the speedometer housing
        Faceplate Removed
        Faceplate Gasket Removal
        Remove the faceplate gasket and the turn signal self-cancel reed switch from the speedometer housing. Gently pull the gasket off and over the odometer reset knob. I managed to save the speedometer gasket
        Gasket removed
        Remove the odometer trip reset knob by turning it clockwise. If it will not unscrew, use needlenose pliers or a hemostat to gently hold the reset shaft but be careful not to bend the face
        Needle Removal and Inspection
        Look for grease between magnetic drive wheel and the driven wheel and the housing
        Grease buildup between the wheels and the housing caused this speedometer to stick and the indicated spead to read slower than normal
        Do NOT bend the spring!
        [continued in next post]
        Regards,
        Scott
          Speedometer Assembly
          Assembly:
          Re-crimp the faceplate retainer ring.
          Just rock and roll; it'll all come together
          The edges are crimped evenly
          Install the odometer trip reset knob by turning it counter-clockwise until it is fully seated
          Replace the gasket and put the speedometer in the bucket
          Put the speedometer back in the instrument cluster
          Regards,
          Scott
            Thread cleanup?
            I can't delete the original post, but I've added some extra pictures. I had to split the new post in half because the forum software told me I had too many images linked.
            Is there some way I can remove my original post?
            Regards,
            Scott
