low rpm signal flash problem
  • gman509
    • 2
    • Tri-Cities, Washington
    does anyone know why my turn signals don't flash at an idle? They work fine at higher rpm's
    ~Michael~
    79 xs1100 standard
    stock (for now!)
  • tarzan
    • 1700
    • Chandler,Az.
    You may want to check voltage to see how much you have at idle.It might just be a flasher going bad or a poor connection somewhere .Like maybe building too much resistance ,then once you rev higher and generate more electricity it has enough power to overcome resistance.My signals work with bike not running with key on.
    80 SG XS1100
    14 Victory Cross Country
      • 8798
      flash
      The flasher unit can be taken apart and the contact points can be cleaned with some fine grit sandpaper. Did this to both of mine, now they work fine.
      • gman509
        • 2
        Thanks- I'll check into that
        ~Michael~
        79 xs1100 standard
        stock (for now!)
        • Ken Talbot
          • 4251
          • Revelstoke, BC
          It is most likely dirty cconnections throughout the electrical system. If things are clean, the flashers will work at idle. This is one of the things I checked out this afternoon on both Tsunami and Purple Reign - with both idling at about 900 rpm.
          Ken Talbot
          • XSPastor
            • Oct 2007
            • 602
            • Gaithersburg, MD
            I agree with everyone here. My low rpm flasher problem went away when I cleaned all of the connections and replaced the fuse box with the automotive spade fuse type.
            Tim Ripley - Gaithersburg, MD
            23mm float height
            120 main jets
            42.5 pilot jets
            drilled stock airbox with K&N
            Jardine 4 to 1 Exhaust
            spade fusebox
            1st and 2nd gear fix
            • HobbyMan
              MeatHead Idiot "GURU"
              • Jul 2006
              • 1801
              • Colleyville, TX
              Its either 2 options. I have the same problem on a few bikes. It could be a low voltage at idle. (sometimes caused by a bad REG/RECT - check the diodes) It is most likely dirty connections. Clean every connection in the signal light system
              Acta Non Verba
