Self revving
  • SiP
    • 438
    • Medicine Hat, Canada
    Self revving
    I guess I don't really need help bt thought everyone could get some amusement out of this.
    Everytime I'm manouvering the bike - ie backing it in to a parking spot - and I go all the way to the right with the handlebars, my bike revs up to about 5k
    I've had some real funny looks from people who obviously think I'm doing it either for attention, or because I can't handke the weight.
    I would guess that I have caught the throttle cable when I tidied up after installing my new coils and wires with a cable tie - guess I'll have to sort it out some time.
    Si Parker
    '81 XS1100H
    Tkat brace, new coils/wires/plugs, refurbed carbs (thanks 81 xsproject), recon'd top end, windshield (thanks dpotter58), resprayed tank and panels, 4-1 exhaust, sweet xs pod filters, in line fuel filters, progressive springs, thick hand grips, jumped headlight relay.
    • 2117
    I usually leave the throttle cable dangling by itself and i don't zip tie it to anything.It kind of lays along side the wiring harness.
      throttle cable
      There is a cable slack adjustment at the top end of the throttle cable. Loosen the lock nut and thread in the sleeve to create a little slack if needed.
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        cable with a mind
        I had to re-route mine to a place where that didnt happen . With my different bars I had an excess of cable/casing .
        XJ1100K
        Avon rubber
        MikesXS black coils
        Iridium plugs w/ 1k caps
        MikesXS front master
        Loud Horns (Stebel/Fiamm)
        Progressive fork springs
        CIBIE headlight reflector
        YICS Eliminator
        • XSPastor
          • Oct 2007
          • 602
          • Gaithersburg, MD
          Tha manual says that you should have 10 degress of throttle grip rotational play in the throttle cable. I guess your problem is one of the reasons for this...
          Tim Ripley - Gaithersburg, MD
          23mm float height
          120 main jets
          42.5 pilot jets
          drilled stock airbox with K&N
          Jardine 4 to 1 Exhaust
          spade fusebox
          1st and 2nd gear fix
