exhaust recommendations
  • Bamper
    • 97
    • Maine
    I bought a xs1100 with no mufflers just the pipes off the heads and 1 got bent removing it from the truck. So does anyone have a good sugestion for a lower priced exahust, im looking for a quick throttle response for mid to high rpm.
    1979 XS1100 SF (production number 572)
    1972 Kawasaki g4 TR-B with high and low transmision
    1974 kawasaki G4
    2003 Polaris 250 Trailblazer
    1975 Yamaha Enduro 175
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    Mac is the only company that even makes them anymore. There are some European companies that I've heard of that build them but you will pay many more times the amount that you paid for the bike. I've been waiting for a MAC 4 to 1 from Dennis Kirk for two months now... You'll sometimes see used OEM and new/used after-market systems on Ebay. Good luck.
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
    • HobbyMan
      MeatHead Idiot "GURU"
      • 1801
      • Colleyville, TX
      You still want those headers?
      Acta Non Verba
        Hey Bamper,
        Aside from what has been mentioned which is true about the availability, or lack thereof, as for the performance range you want, you'll want to look into the 4-1 style. They are usually tuned to scavange better in the mid/higher rpm ranges. If you want lower end rpm grunt, then it's suggested to go with 4-2 style!
          • 2117
          Years ago i thought Dennis Kirk had Kerker/Supertrapp exhaust systems in stock.That was a few years ago.My Kerker is still on my SG after 22 years.Also try Starcycle in CA.
          • tazman547
            • 11
            • San Bernardino, CA
            I ordered a set of MAC's from these guys.
            http://www.cyclepages.com/
            They are back ordered till the 8th.
