Here's another way to repair a broken float post:
![](http://img.photobucket.com/albums/v491/kmtalbot/carbs/floatpost.jpg)
I believe the carb body is drilled and tapped, and the end of the brass post is threaded. The hole for the pin is cross-drilled after the new post is fitted.
