help- missing key part
  • kjoslin
    • 64
    • Central NY
    I know it was there when I took the rear axle out...but sure can't find it now. I'm not sure what you call it (spacer? dust shield?) but I need it. Does anyone out there have one I could buy?
    On another note I've checked other threads regarding the order of things as you put the axle back in...but I'd like to verify that for an SG...
    is this right???? looking from the rear...
    Castle nut (on L side)...axle through wheel; THE PART I'M MISSING; caliper bracket; torque plate; pinch bolt.
    Thanks!!
    1980 XS1100SG
    “You start the game with a full pot o’ luck and an empty pot o’ experience... The object is to fill the pot of experience before you empty the pot of luck.”
    Only a Biker knows why a dog sticks his head out of a car window.
    • 3189
    This link may help you with the part name
    • kjoslin
      • 64
      • Central NY
      I couldn't get the link to work.
      1980 XS1100SG
      • kjoslin
        • 64
        • Central NY
        got it to work....
        3H3-25377-00-00 COLLAR, WHEEL
        Any idea where I can get one?
        1980 XS1100SG
          • 8753
          dust cover
          This link is for a 79, should be the same. look under rear wheel.
            • 8753
            collar
            Try Bikebandit.com
            • kjoslin
              • 64
              • Central NY
              They have it...but want !9.00 plus shipping (ouch). I'm still hoping to find mine (I'll tear the garage apart tomorrow.
              Regarding my other question, is the parts lineup correct for an SG?
              thanks, Keith
              1980 XS1100SG
                • 8753
                lineup
                That looks like the setup on my 79 Special, except I have another small spacer to the right of my torque plate. I'm not 100% sure that mine is set up correct (rotor not exactly centered in caliper bracket).
                  • 2062
                  I have a spare rear wheel off of a 80 SG.I will check to see if i have one.If i do-Its yours.
                    Re: lineup
                    That is not correct phil. The sequence is from inside out: Collar, caliper bracket, and torque plate. The axle has a shoulder that will seat it against the collar, cal brcket, and torque plate. The pich bolt on the frame is to be tightened last. The frame will center itself on the axle, and the pinch bolt will hold it. There will be some of the axle visible between the torque plate and the frame.
                      • 8753
                      spacer
                      Thanks for pointing that out, John. The spacer I have in there must be left over from when I was running a 17" rear wheel on there (had to make up spacers because of narrower rim).
                      • kjoslin
                        • 64
                        • Central NY
                        thanks Yam...I'll wait to hear from you.
                        1980 XS1100SG
                          • 2062
                          I have a wheel but there is a big metal washer looking thing on mine not the black piece.
                          • kjoslin
                            • 64
                            • Central NY
                            I think I'm good Yam, I just found out that Andreas is sending me one.
                            Thanks for checking.
                            Keith
                            1980 XS1100SG
