I was just thinking of how cool it would be to make a Quad exhaust for my SG. My question is would it work if each cylinder had its own pipe?
Custom Exhaust Question
Yes, it will work. Will it work as well as stock or a 4 into 1 header, NO. The only time it will work well is if you have a "blown" engine, and are pushing air into the chambers all the time.Ray Matteis
Re: Ray
Originally posted by John
How did Honda do it for so long with the normally asperated fours of the 70's? So many of those bikes had 4-4 exhaust back then.
Straight pipes will work just fine as long as you are trying to do most of your work at high-RPM, WOT. Aside from that they will operate like C$@p. You can actually get much better performance from a well tuned header.Mike Giroir
79 XS-1100 Special
DiverRay, TADracer, I have to disagree! I have built 4-1, 4-2, and 4-4 exhaust on a number of XS1100's, and as long as the carbs are properly tuned, they all have worked fine, at all RPM ranges. Granted the 4-1 does work best, but even the 4-4 is a very workable set-up for the XS. Just my thoughts on the matter, for what it's worth.Jim Horton
Myrtle Beach SC 29588
843-274-5045
Technically, any change to the intake or exhaust warrants looking into jetting.
A 4 into 4 would work and sound better if it had cross-over tubes (IMHO).
The only way you will get a 4 cylinder in-line to sound like a V-twin is to run two of the exhaust ports (180 degrees out) through a real good muffler and the other two straight out. The performance will be about the same as a V-twin (could not resist).
My 'X's XS lost a muffler on her 4 to 2 and it sound so much like a Hardly, the neighbor (Hardly driver) came running over thinking I had bought one.DZ
Vyger, 'F'
"The Special", 'SF'
'08 FJR1300
