Okay so after reading the posts further and due to the lack of carb kits here in town, I delved back into the bike. Started it up and the enging puked gasoil all over the place. I have the crankcase tube dropping its load infront of the rear tire...thinking thats a poor place now..so WILL need help figuring what to do with that...
So changed plugs and gasoil...TERRIBLE!! Crankcase filled with oil...so no lubrication what-so-ever to the engine. Change the oil...bike has an aftermarket oil cooler on it so i added about 4 quarts total thinking that would be cool. Start the bike, all the pipes are hot...idling a bit low so i turned the screw up...sounds better. Perviously I tightened the header bolts cause they were loose...have no idea how tight, like TIGHT or just real snug...so...
Enging is running, no more backfiring or belching, coming down off the revs pretty well then I hear this SCREAMING SCREECHING kind of wooshing sound...engine stumbles a bit and and wants to die-oil light flickers...give er a little more gas...the scenario repeats...take it for a wee wee bit of a spin and Im losing PUMPING oil out the crankcase tube...all over the rear tire...uhuh...not good...park the bike. So some questions....the left bank pipes are quite blue...will this turn back chrome or golden as the bike richens or is that permanent? What the heck is the screaching?? How tight do I tighten the headers...why is oil dumping out the crankcase vent tube? And last but not least, should I be able to shift the cycle into more gears than first when it is not running or simply idling...ALL I can feel is first, doesnt seem to want to kick up into any other gears...had to adjust the clutch cable cause putting it into 1st killed the engine...I only adjusted it at the lever though
Again, thanks for any and all responses. BTW, tach seems to be dead...
TAHDAH...hey it was a $500.00 Bike...
