Petcock Repair
  • Getty
    • Feb 2008
    • 127
    • Denver, CO
    Petcock Repair
    I have ordered the repair kit from george at Ebay. Looks like that kit does not come with the gasket between tank and petcock.
    I started making one from a Fibre sysnthetic rubber gasket sheet I have. Noticed that it is not tall enough once placed in the petcock groove. Should I double up gasket meterial? Which gasket meterial is safe for gas? My gasket kit came with...
    Fibre Gasket Paper
    Cork Rubber
    Fibre and Sysnthetic Rubber meterial
    Rubberized Hi Density Fibre Material
    Not sure what is best.
    Getty
    1980 SG
  • tarzan
    • 1700
    • Chandler,Az.
    You would probably be time and heartache ahead to buy new ones.You might try bike bandit ,I think that is where I got mine a few months back.My memory isnt perfect though.LOL.I also thought I saw someone claim you can get them through yamaha
    too,but I'm not sure about that either.
    OK so maybe I dont know much but its all I know.
    80 SG XS1100
    14 Victory Cross Country
    • John
      • 5117
      There is no gasket between the tank and the petcock. There is a large oval O ring that sits in a groove in the petcock. You'll see it when you pull the petcocks off. That will be in georgefix's kits.
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        Yamaha still sells them. They're 6 bucks each at this site.
        For some reason, there's not a parts break-down for the 80SG fuel petcocks so I checked the 81 'cause they're the same ones.
        Tim Ripley - Gaithersburg, MD
        23mm float height
        120 main jets
        42.5 pilot jets
        drilled stock airbox with K&N
        Jardine 4 to 1 Exhaust
        spade fusebox
        1st and 2nd gear fix
        • XSPastor
          • Oct 2007
          • 602
          • Gaithersburg, MD
          You could also just use a neoprene O-ring of the right size... You might have to use some three-bond to get them to stay in the groove while you're tightening them down.
          23mm float height
          120 main jets
          42.5 pilot jets
          spade fusebox
          • XSPastor
            • Oct 2007
            • 602
            • Gaithersburg, MD
            One of the O-rings on this page might work. They're only two bucks. You'll have to do a little research or ask here if anyone has used them.
            23mm float height
            120 main jets
            42.5 pilot jets
            spade fusebox
