Pick-up coil air gap
  • Peter
    • 68
    • Hamilton/Ontario
    Hello i just switched my 4RO timing plate for a 2H7 one and I can't find anywhere is to what the air gap should be for my pickup coils. I did it so I can adjust the timing on my bike. I had to swap the pickup coils...I guess I should have took a measurement before ripping everything apart...:-(
    Tks
    Peter.
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    I believe the pickup coil to actuator gap is 0.7mm/0.0275" I saw that in a TopCat post somewhere here. You could search his posts by user name to find it yourself...
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
    • randy
      • Dec 2003
      • 4521
      Yes, .7 mm is correct
      • Peter
        • 68
        • Hamilton/Ontario
        Good thanks a lot guys, I'll set them at that gap!
        Cheers
        Peter.
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          Anything
          close to that will work fine. The way those things work is they work or they don't. There is no in between nor different intensity ratings at different distances.
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
          • Peter
            • 68
            • Hamilton/Ontario
            Man I took off the timing plate and put the original one back on. The bike will not stay running, I can get to bit for a second but than that's it! I used brass feeler gauges but it no where near starts like it used to. I can only think it is the air gap setting, how accurate does the setting has to be?? I'm going to trailer the bike to a local mechanic for him to get it to run and for a safety and cert...
            Ugg
            Peter.
            • planedick
              • Mar 2005
              • 2068
              Ballast resistor....
              If it only runs while you have the starter button pushed, it's because the ballast resister is disconnected..... Stops when you release the starter button?
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              • Peter
                • 68
                • Hamilton/Ontario
                My bike is the one that they stopped using the ballast resistor. My TCI is the 4R0 not 2H7....I have the Midnight Special model.
                Cheers
                Peter
