Smoke a Rolling
  • exquized1
    • Oct 2006
    • 644
    • Polo Il.
    Smoke a Rolling
    Yesterday my son and I was outside working on my bike. The battery was completely dry (only 2 months old). Yes I have an overcharging issue due to the fact of the PO bypassing the ignition switch. So I pulled out that battery and put in a new one again. I hit the start button my son said the brake light was on. turned over started then a pop and a lot of smoke came rolling out of under the gas tank. OH (*&*^9 I hurry and kill the bike pull the seat and gas tank to see nothing. All the fuses are fine and didn't see any wires damaged. Looks like I will be down for a while. Damn just when it is the best riding time. I am giong to rewire the beast with the wires sent to me by Chip. I am also getting a ignition switch so maybe this will not happen again.
    68 Honda Cl350 (sold)
    76 Honda Cb 400 super sport
    79 special (skull bike)
    79 special (parts bike w/title)
    79 special
    80 standard full dress (Sat 24 years)
    81 special (parts for now trying to get the title)
    81 kaw 750 ltd (sold to brother-in-law)
    80 650 maxim (fixing for wife)
    81 650 maxim
    81 Xs 650 special ( No title found in a barn)
    88 Zx 600r (Sold)
    01 Gz 250
  • exquized1
    • Oct 2006
    • 644
    • Polo Il.
    recharged the old battery and reinstalled it. hit the start button and she came alive. No smoke this time not even sure what happened last time. took her for a ride and took the tank off after I got back. No signs of any damage. this makes me wonder what was smoking so bad the last time?
    79 special
    81 650 maxim
    88 Zx 600r (Sold)
    01 Gz 250
      • 8863
      smoke
      Mabye the bottom side of the voltage regulator? Overcharging? I've seen car regulators fry from the back, but never one from an XS.
        It's down further, but you might check the cable connection going to your starter. It could have been loose and arced there, and smoke rose to make it look like it came from under the seat?
        • GNEPIG
          • Apr 2005
          • 1657
          • fl
          Maybe you have an XS model that was intended to be shipped to the UK.
          Electrical Theory by Joseph Lucas:
          Positive ground depends upon proper circuit functioning, the
          transmission of negative ions by retention of the visible spectral
          manifestation known as "smoke". Smoke is the thing that makes
          electrical circuits work; we know this to be true because every time one lets the smoke out of the electrical system, it stops working.
          This can be verified repeatedly through empirical testing.
          When, for example, the smoke escapes from an electrical component (i.e., say, a Lucas voltage regulator), it will be observed that the component stops working. The function of the wire harness is to carry the smoke from one device to another; when the wire harness "springs a leak", and lets all the smoke out of the system, nothing works afterwards. Starter motors were frowned upon in British Automobiles for some time, largely because they consume large quantities of smoke, requiring very large wires.
          It has been noted that Lucas components are possibly more prone to electrical leakage than Bosch or generic Japanese electrics. Experts point out that this is because Lucas is British and all things British leak. British engines leak oil, shock absorbers, hydraulic forks and disk brakes leak fluid, British tyres leak air and the British defense establishment leaks secrets...so, naturally, British electrics leak smoke.
          • exquized1
            • Oct 2006
            • 644
            • Polo Il.
            LOL but with the change of batteries the leak seamed to dissappear. Not sure whats up!
            79 special
            81 650 maxim
            88 Zx 600r (Sold)
            01 Gz 250
              • 5069
              Just for grins, try cleaning the contact of the vR with the frame where it mounts. It depends on a good fram ground to meter the voltage.
              QUOTE]Originally posted by exquized1
              LOL but with the change of batteries the leak seamed to dissappear. Not sure whats up! [/QUOTE]
              • Da-Bubble
                • Jun 2006
                • 353
                • Oklahoma City, OK
                Maybe it backfired thru the carb and that was the smoke. Did it smell like burning electrical?
                1979 XS11 Special (slightly modified)
                dubbed the "Mad Mosquito"
                MikesXs Pod Filters
                MikesXs 35k Coils
                8mm plug wires
                42.5 Pilots 142.5 Mains
                (Carb tune by GNEPIG Performance)
                Kerker 4-into-1
                Shaved emblems
                Progressive frt springs lowered 1.5"
                Progressive 11.5" rear shocks
                Harley Dyna rear fender chopped
                Custm side mt tag (apparently illegal)
                Custom Dual Headlights
                Lots of time and hard work.
                • Crazcnuk
                  • Aug 2006
                  • 2980
                  • Hinton, AB, Canada
                  Ah, Lucas, the Prince of Darkness...
                  '05 ST1300
                  • birch
                    • May 2006
                    • 73
                    • michigan
                    GNE, that was a brilliant piece of writing. I have it saved in a word document. It might be plagerized in the future!
