Yesterday my son and I was outside working on my bike. The battery was completely dry (only 2 months old). Yes I have an overcharging issue due to the fact of the PO bypassing the ignition switch. So I pulled out that battery and put in a new one again. I hit the start button my son said the brake light was on. turned over started then a pop and a lot of smoke came rolling out of under the gas tank. OH (*&*^9 I hurry and kill the bike pull the seat and gas tank to see nothing. All the fuses are fine and didn't see any wires damaged. Looks like I will be down for a while. Damn just when it is the best riding time. I am giong to rewire the beast with the wires sent to me by Chip. I am also getting a ignition switch so maybe this will not happen again.
Smoke a Rolling
Smoke a Rolling
68 Honda Cl350 (sold)
76 Honda Cb 400 super sport
79 special (skull bike)
79 special (parts bike w/title)
79 special
80 standard full dress (Sat 24 years)
81 special (parts for now trying to get the title)
81 kaw 750 ltd (sold to brother-in-law)
80 650 maxim (fixing for wife)
81 650 maxim
81 Xs 650 special ( No title found in a barn)
88 Zx 600r (Sold)
01 Gz 250Tags: None -
recharged the old battery and reinstalled it. hit the start button and she came alive. No smoke this time not even sure what happened last time. took her for a ride and took the tank off after I got back. No signs of any damage. this makes me wonder what was smoking so bad the last time?68 Honda Cl350 (sold)
79 special
81 650 maxim
88 Zx 600r (Sold)
01 Gz 250 -
smoke
Mabye the bottom side of the voltage regulator? Overcharging? I've seen car regulators fry from the back, but never one from an XS.
07 Triumph Tiger 1050
☮Comment
It's down further, but you might check the cable connection going to your starter. It could have been loose and arced there, and smoke rose to make it look like it came from under the seat?Try your hardest to be the kind of person your dog thinks you are.
Maybe you have an XS model that was intended to be shipped to the UK.
Electrical Theory by Joseph Lucas:
Positive ground depends upon proper circuit functioning, the
transmission of negative ions by retention of the visible spectral
manifestation known as "smoke". Smoke is the thing that makes
electrical circuits work; we know this to be true because every time one lets the smoke out of the electrical system, it stops working.
This can be verified repeatedly through empirical testing.
When, for example, the smoke escapes from an electrical component (i.e., say, a Lucas voltage regulator), it will be observed that the component stops working. The function of the wire harness is to carry the smoke from one device to another; when the wire harness "springs a leak", and lets all the smoke out of the system, nothing works afterwards. Starter motors were frowned upon in British Automobiles for some time, largely because they consume large quantities of smoke, requiring very large wires.
It has been noted that Lucas components are possibly more prone to electrical leakage than Bosch or generic Japanese electrics. Experts point out that this is because Lucas is British and all things British leak. British engines leak oil, shock absorbers, hydraulic forks and disk brakes leak fluid, British tyres leak air and the British defense establishment leaks secrets...so, naturally, British electrics leak smoke.
LOL but with the change of batteries the leak seamed to dissappear. Not sure whats up!68 Honda Cl350 (sold)
79 special
81 650 maxim
88 Zx 600r (Sold)
01 Gz 250Comment
Just for grins, try cleaning the contact of the vR with the frame where it mounts. It depends on a good fram ground to meter the voltage.
QUOTE]Originally posted by exquized1
LOL but with the change of batteries the leak seamed to dissappear. Not sure whats up! [/QUOTE]Skids (Sid Hansen)
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
Maybe it backfired thru the carb and that was the smoke. Did it smell like burning electrical?1979 XS11 Special (slightly modified)
dubbed the "Mad Mosquito"
MikesXs Pod Filters
MikesXs 35k Coils
8mm plug wires
42.5 Pilots 142.5 Mains
(Carb tune by GNEPIG Performance)
Kerker 4-into-1
Shaved emblems
Progressive frt springs lowered 1.5"
Progressive 11.5" rear shocks
Harley Dyna rear fender chopped
Custm side mt tag (apparently illegal)
Custom Dual Headlights
Lots of time and hard work.Comment
