grips off
  • SiP
    • 438
    • Medicine Hat, Canada
    grips off
    I assume the old handlebar grips are stuck/pushed on? So all I have to do is pull or cut them off, clean the surface and stick the new ones on?
    Thought I'd ask before doing something daft - again
    Si Parker
    '81 XS1100H
    Tkat brace, new coils/wires/plugs, refurbed carbs (thanks 81 xsproject), recon'd top end, windshield (thanks dpotter58), resprayed tank and panels, 4-1 exhaust, sweet xs pod filters, in line fuel filters, progressive springs, thick hand grips, jumped headlight relay.
    Easy way is use a SHARP knife to slit the old grips and take them off. Be careful with the right grip, and the throttle tube is plastic. I and many other people use hair spray to install the new grips. Spray it inside the grip, push on and position, let dry. It helps the grips go on, and then sticks them to the bar and throttle tube WITHOUT the worry of how to take them off later.
    • randy
      • Dec 2003
      • 4521
      Yes, and the can of Aquanet on the shelf in the garage is good for a few laughs!
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        Oft times, if one wishes to save the old grips and has an air compressor, they take an air nozzle, insert it underneath the edge of the grip and blast it away from the handlebar.
        This technique is also used when installing. The blasts of air inflate the grip and one can then inch it up the handlebars.
        As are my various shades of fingernail polish, Randy... for marking vacuum lines and open electrical connectors.
        • SiP
          • 438
          excellent - i'll get on it tonight.
          What's aquanet?
          Si Parker
          '81 XS1100H
            What's aquanet?
            A brand of hair spray, usually cheap. that's all you need, is the cheap stuff. The grips don't care if they feel like rubber!
            • customaxe
              • 39
              • Mass
              Aquanet.. is the aresol version of gorrilla glue .. and i would like to thank all of you who used it in the 80's ..and you know you did !!! Riders Supporting Global Warming .. itsa beautiful thing
              82 XJ 1100 .. " Da Sqirrel Mobile
              Dear God man !! what are you doing with that squirrel ?!!!!
              Seriously... I'm not happy ..till You're not happy
              • dpotter58
                • Aug 2004
                • 1866
                • Southern Maryland
                I used aquanet to power one huge potato cannon a few yeas back..
                1980 LG
                1981 LH
                • Da-Bubble
                  • Jun 2006
                  • 353
                  • Oklahoma City, OK
                  I still use it!!! Spray it on after the hair Gel and the huge Alcohol content will dry your hair in 30 minutes....I too discovered Aquanet after using it for Spud Gun Propulsion.
                  1979 XS11 Special (slightly modified)
                  dubbed the "Mad Mosquito"
                  MikesXs Pod Filters
                  MikesXs 35k Coils
                  8mm plug wires
                  42.5 Pilots 142.5 Mains
                  (Carb tune by GNEPIG Performance)
                  Kerker 4-into-1
                  Shaved emblems
                  Progressive frt springs lowered 1.5"
                  Progressive 11.5" rear shocks
                  Harley Dyna rear fender chopped
                  Custm side mt tag (apparently illegal)
                  Custom Dual Headlights
                  Lots of time and hard work.
                  • customaxe
                    • 39
                    • Mass
                    it also is a GREAT replacement for a helmet.. 1/2 a can and u could punch a hole in 6ft of tarmac... and never hurt your bean it's what we used on the big dig to hold back the ocean.. 8 guys 12 cans and just stood there with there beans holding the water back.. and you thought they were just standing there doing nuttin...shame on you !
                    • CarolynS
                      • 369
                      • Massachusetts
                      The impossible beehive...
                      Remember those ridiculous 60's high school yearbook photos with the 3 foot tall beehive hairdo's?
                      That's Aquanet...
                      The power to defy gravity,
                      The power to hold a 'slurry wall'-Jim,
                      The power to hold your handgrips...
                      Ah,...the power!
                      Makes one giddy, it does!
                      80 XS1100G w/ Windjammer-the Witch
                      79 XS1100F
                      "Look Ma! No hands!...."
                      • prometheus578
                        • Aug 2004
                        • 4012
                        • Olympia , Wa.
                        "A Little Dab'll Do Ya!"
                        Da-Bubble...
                        What the hell is "Hair Gel"?
                        Is that like my Dad's Brylcreem?
                        What's the matter with people these days?
                        Hair Gel....
                        "Oh, you need some "product" in your hair and you'll look faaaabulous!"
                        Hair gel...
                        "Bed Head"....
                        "Comb your stinkin' hair, you loser... and straighten that tie!"
                        • Hammerhead1st
                          XStremely XSive(Deceased)
                          • Jul 2007
                          • 330
                          • Lawrencvile, GA
                          Actually, I use stove black spray paint...lubes the grip going on, sticks it there till you cut it off...or inject a lil paint thinner with a syringe...
                          "Rat Rod"
                          79 XS1100 Standard
                          87 VMAX cans
                          Cheap Japanese Tires
                          Cobalt Blue Rattle Can Paint
                          Custom Lighting on a Budget
                          Perry Center Fire Department
                          Perry Emergency Ambulance
                          "If we don't do it, who will?"
                          Some people have one of those days, I have one of those lives...
                          • vanhump
                            • Feb 2004
                            • 142
                            • the virginia mountains CRAIG COUNTY
                            You had me wondering there for a minute Hammer. I thought you were using it for hair spray. Cheaper than color back.
                            POTTS CREEK EXPRESS
                            IF YOU AINT THE LEAD DOG
                            THE VIEW IS ALWAYS THE SAME
                            1980 G Full Dresser
                            • SiP
                              • 438
                              Well they're on and look great. Missus wasn't overly impressed with me using her mega expensive salon hair spray - but sh'ell get over it. Th important thing is that the bikes OK!
                              Si Parker
                              '81 XS1100H
