Final Drive Gear
  • dspshemp
    • Dec 2002
    • 42
    • Key Largo, FL
    Final Drive Gear
    OK, so now that I know what caused my bike to suddenly lock up, I need to know where to find a part. It is the gear which connects the driveshaft to the final drive. I do not know the technical name, but it transfers power from the driveshaft then sends it perpendicularly to the final drive gear whick lines up on the wheel. The bearings are welded to the part, and there doesn't seem to be any way to remove the bearing from the gear. If anyone knows where to get one, or has one in good condition, that would be great!! Thanks again everyone!! RB
  • uk1.1s
    • Oct 2002
    • 365
    • Surrey UK
    Nasty
    The part you've got trouble with is the 'middle drive gear'
    Not had trouble with mine - so no direct advice
    However, have discussed problems with Bob (via email) at Merriam cycles. He and his mechanics are really switched on when if comes to XS11's
    Failing that - I'd look for a whole replacement middle drive gear from a bike parter (breaker).
    Good luck
    XS1.1 sport - Sold June 2005 :-(
    Guzzi 850
    Z1000
    • sixtysix
      No XS but XSive as can be!
      • 1958
      • Central New York State
      Sounds like the part is in the hub and not in the middle gear drive.
      Gary Granger
      • Bill__Woods
        • 281
        • Circleville, Ohio
        Hello dspshemp,
        I think there is some conufusion here as to which parts you are having problems with. I would go to
        and look under OEM parts. They have online parts microfiches and you cna find out the correct name of the part you are looking for. If you find out what is broken, one of the list members or your local bike salvageyard may have the parts you are looking for.
        Also if you do not have it yet, I would suggest emailing Rob Mills and purchase a copy of the XS/XS1100 CD, I believe the money goes to charity.
        Find out what part you need and over half the work is already finished!
        Bill Woods
        1981 Yamaha XS1100SH (Eleven Special)
        1985 Kawasuki GS425 Mojave ATV
        2006 Yamaha Wolverine 450 4x4 ATV
        • sixtysix
          • 1958
          Pick out the part on this picture and let me know what you need.
          Gary Granger
          • dspshemp
            • Dec 2002
            • 42
            • Key Largo, FL
            The reason I don't know what to call it is because it is the unnumbered part between 7 & 16 on the diagram. It is an important part, and I have no way of figuring out the proper name for it, and I cannot order it from Yamaha without a part #. In addition, it is the same in the Clymer manual, PartsFish, Bike Bandit, and the Yamaha OEM CD. HELP ME!!!!! Thanks. RB
            • wpc57
              • Feb 2003
              • 112
              • Benton, IL. (Southern IL. 300 miles south of the windy city, and Aprox. 100miles east of the Gateway to the West.)
              MAYDAY............
              looks like trouble to me .... and a trip to the salvage yard
              wpc57
              '81LH Midnight Special "Margret"
              I ain't as good as I once was..but I am as good once as I ever was.... (Toby Keith)
              • sixtysix
                • 1958
                That would be a pinion gear in a car, so I would say it is the same part here. Since the ring and pinion wear together, you always change them together. So I would say you are looking for a whole new rear gear (or rear hub) assembly. Should be fairly cheap, I think Venture and V-max will also work. Good Luck, I have one I know leaks , I was just keeping it for parts, if worse comes to worse I will send it to you for shipping and handling costs (not cheap they are heavy) and I will have to hassle with a heavy duty box. If you are interested in this (as a last resort) please contact me by private e-mail.
                Gary Granger
                • dspshemp
                  • Dec 2002
                  • 42
                  • Key Largo, FL
                  I am trying a few options, and I need to call my nearest salvage yard (85 miles away) tomorrow, since they have closed for the day. Will keep you all updated!! Thanks. RB
                  • CA.XSer
                    • 189
                    • Jerome, ID.
                    Final Drive on Ebay
                    http://cgi.ebay.com/ebaymotors/ws/eB...category=35600
                    Gary
                    79sf
                    78e
