Generator
  • Peter
    • 68
    • Hamilton/Ontario
    Generator
    Hello any reason why when I turn the ignition key to the "ON" positon I hear and feel a clicking sound on the alternator cover. And the green neutral light does not come on and I can not turn over the engine. But when I jump out the starter relay it will turn over. THen after a while it is fine.
    Any ideas??
    TKs
    Peter.
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    suggestion
    Check your starter relay and wiring ? Just a guess
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • AlanB
      • Oct 2006
      • 705
      • Scotland
      Hi Peter,
      Assuming that you have an XS, When the power goes "ON" the magnets start to work, so if something clicks, something is moving!
      Check that both sets of coils are secure in the cover; the inners are held by the three allen screws you see, the outer is held by bolts inside the cover.
      If you have an XJ, I really don't know!
      AlanB
      If it ain't broke, modify it!
