carb jetting
  • carb jetting
    so I put on the 4/1 exhaust and put in bigger main jets and pilot jets, the main jets seem to work but what size pilots should I use
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    size
    the mains are 142.5 and I tried the 47.5 and 50 for pilots but they are not working.
    It wont idle , and it runs like crap until about 3800 rpm then winds up real nice after 4000rpm
    91 kwaka kz1000p
    Stock
      Have you synced the carbs?
      Still, it sounds like you have other carb issues. Has the bike beem sitting up for a while? Sounds like you have some plugged or restricted low speed circuits.
      Possibly, try turning out the IMS screws
      to 2 or 2 1/2 turns out. Maybe.
      Still the 47 or 50 pilots should be plenty.
      Try a plug chop at sub 4000 RPM with new plugs for additional info.
      John
      Now: '78 XS1100E 750 FD Mod (Big Dog)
      '81 CB900C ( 10 Speed)
      '78 CB750F ( The F)
      '76 CB400F ( The Elf)
      New '82 Honda MB5 Ring Ding
      Then: '76 CB550K
      '78 CB750F
      '84 VF1100S
      And still Looking!
        yeah
        the carbs are synced but I found out my petcocks were both free flowing on all settings I guess Ill clean the carbs again
        91 kwaka kz1000p
        Stock
          oh yeah
          I switched to my other tank with working petcocks also
          91 kwaka kz1000p
          Stock
            ims
            ??? and what do you mean by chop
            91 kwaka kz1000p
            Stock
              plug chop
              91 kwaka kz1000p
              Stock
                Plug Chop
                Run at desired RPM for desired mixture, and then hit kill switch while pulling in clutch lever, Come to a stop and check plug condition. Why I say use new plugs for the most accurate view. Should tell you if you are running lean or rich.
                HTH.
                John
                John
                '78 CB750F ( The F)
                Then: '76 CB550K
                '78 CB750F
                '84 VF1100S
                And still Looking!
                  He means run it under load at 4000rpm or less at normal operation temperature, then hit the kill switch and coast to a stop (clutch in)...like what you hear at the end of a NASCAR qualifying run when they kill the ignition and coast into the garage area to see how the plugs read. Sub 4000 rpm because that's where to problem is...just coast to a stop and pull the plugs to check for rich/lean condition.
                  Guy
                  '78E
                    oops..too late!
                    Guy
                    '78E
                      Thanks Guy,
                      That sounded better than mine
                      John
                      '78 CB750F ( The F)
                      Then: '76 CB550K
                      '78 CB750F
                      '84 VF1100S
                      And still Looking!
                        You put a 4/1 on - did you do anything on the other side of the carbs. Might try a freer flowing air filter and drilling the box so that you are addressing both sides of the equation. Also, pilots at 47.5 are two sizes too big for just a 4/1.
                        • #13
                          45's are stock on the 78's, so 47.5 (1 size up) is reasonable for a 4-1. But probably not necessary.
                          Drilling out the airbox or otherwise increasing intake flow will make it leaner and leaner. Sounds like thats the problem to begin with.
                          John
                          '78 CB750F ( The F)
                          Then: '76 CB550K
                          '78 CB750F
                          '84 VF1100S
                          And still Looking!
                          • #14
                            plug chop
                            ah I understand now, will do btw I have pod filters I think Im going to pull the pilots and clean and see if that will help
                            91 kwaka kz1000p
                            Stock
                            • #15
                              also
                              the pipe I m running is a bassani 4/1 which is a litlle better than a straight pipe
                              91 kwaka kz1000p
                              Stock
