Getting 100mpg!!!
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    Getting 100mpg!!!
    I'm getting 100mpg on my xs! ok well I assume there is something wrong with the trip-odometer. The first tank I thought I might have forgoten to reset it but this time I'm sure I reset it and I have 402.7mi till the low fuel light came on. Anyone take one apart and service it? Any Ideas? Anyone got a spare spedo they want to sell?
    Thanks!
    1979 xs1100 Special -
    My Bike:
    [link is broken]
    speedo
    I've taken both of mine apart and lubed them. I used WD 40 and worked ok, but there is probably somthing better to use?
    I always set my trip odometer to 999.9 when filling up. I find that when setting to 000.0, sometimes it will flip the first number over too. = extra 100 miles!
    • stevec5000
      • Oct 2002
      • 131
      • Mesa, AZ
      Mine sometimes jumps a couple hundered miles when it shouldn't but spraying with WD-40 usually fixes it for a few more years.
      72 TS185
      77 XS750
      78 SR500
      80 XS850
      80 XS1100 Midnight Special
      81 Seca XJ750RH
      • psycoreefer
        • Feb 2008
        • 1557
        • Minden, NV
        Even with an extra hundred I still shouldn't be showing 400+ before reserve. Its strange because the speedometer seems accurate. Anything I should look out for when I tear into it?
        My Bike:
        [link is broken]
        • stevec5000
          • Oct 2002
          • 131
          • Mesa, AZ
          It must have jumped 200-300, they do that sometimes too. You have to remove the mechanism from the housing and take off the needle and dial to get to the odometer part although it might be possible to just spray some in the holes for the dial lamp. It's hard to get the needle off without breaking it so be careful.
          72 TS185
          77 XS750
          78 SR500
          80 XS850
          81 Seca XJ750RH
            If you take the speedo out of it's chrome housing, there is a way to lube the plastic gears that drive the odo. Right above where the cable driven gear is a long reed switch. Carefully remove it and that will expose the drive gears for the odo. I had to replace my 160 speedo because these gears had stripped out, and I couldn't replace them from another unit, and I'm afraid you may have to also.
              Hi Brian,
              does the main, non-trip odometer still work? If so, just remember the last 3 digits every time you fill up. 100 miles further than that and start looking for a filling station.
                Hi psycoreefer,
                Incase it is as simple as mine. After installing a new windshield the clutch cable routing caused it to rub on the reset knob and add random distance. i just tiewrapped it out of the way. hope this helps.
                Maxim Phil
                • egsols
                  • Jan 2006
                  • 1090
                  • Barrie, Ontario, Canada
                  Hey Maxim and psyco,
                  Back in 79 Yamaha actually posted a tech bulletin to their mechs advising on rerouting the clutch cable to prevent it from jumping the trip meter.
                  Ernie
                  • psycoreefer
                    • Feb 2008
                    • 1557
                    • Minden, NV
                    Hey, I never would have thought about the cables rubbing on the reset knob. I'm going to check it out when I get home.
                    My Bike:
                    [link is broken]
                    • Wildkat
                      XS Special Gurette
                      • Apr 2004
                      • 3416
                      • Location, Location
                      Occam's razor
                      Cable routing was the problem on mine too... Man! was I ever getting some great gas mileage... until I fixed it.
                      Of course, the inverse, I got terrible gas mileage on my FJ when my speedo cable came loose...
                      81 SH Something Special
                      79 SF MEAUQABEAUXS
                      81SH Nor'eas tah (Old Red)
                      80 LG Black Magic
                      78 E Standard Practice
                      James 3:17
                      “Alis Volat Propriis”
                      Yamaha XS 1100 Classic
                      For those on FB
                      • egsols
                        • Jan 2006
                        • 1090
                        LMAO!!!!
                        Ernie
