hyper-lites install
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    hyper-lites install
    Just got a set of Hyper-Lite brake lights. Two units of 8 LEDs, each of which can either flash continuously when brake is applied or flash for 5 seconds and then stay solid. I think I'll choose the second option. They also remain on as running lights at a lower intensity. Gonna mount them on either side of the license plate.
    Being an electrical simpleton, I would like to ask folks here (Randy) which wires are which on our taillight. There is a blue and a yellow wire leading to each bulb, and a black wire/spade connector to each. I need to know which is the brake wire, the taillight wire and the ground (black I presume)... Thanks
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
  • 81xsproject
    • 3185
    • Fortuna, CA
    That's cool, what did they cost? I just bought the modulator unit for $30.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • mro
      • 4276
      • Hayward, California
      Blue be running (also goes to license plate light)
      Yellow be brake
      Black ground
      mro
      • Cobia
        • Jul 2007
        • 1587
        • Palm Beach County, Fl
        Auxiliary LED Flashing Brake Lights
        HI,
        I did the same mod to increase my visibility from the rear. All for under $60. Check out this link for the info:
        I got two 21 LED arrays that measure 2" X 6" and fit perfectly on both sides of the license plate when you mount all of these on a car size license plate mount/holder.
        Inventory:
        Truck LED arrays (2) $30
        Adjustable Flasher $20
        Bell license pplate mount $8
        1 Hr of work PRICELESS !!
        WORD OF CAUTION!!
        You do not want to cut your brake light wire, just tap into it.
        You do not want to affect the regular operation of the stock light should the mod fail for whatever reason.
        Hope this helps, good luck
        1980G Standard, Restored
        Kerker 4 - 1
        850 Rear End Mod
        Automatic CCT
        1980GH Special, Restored
        '82 XJ1100 (Sold)
          • 6763
          hyper lites
          hey Dean...I just did this to my ST1100 last fall...mine have 16 LEDS per side and were supposed to flash 5 times in five seconds then go solid with the brake lite.Mine actually flash 19 times in 6 seconds before going solid....ppl behind me stop way back or either that then they are slower to approach me...As for the wires...the hyperlites should have an instruction page that explains the color coding for the different makes of bikes...Anyways the lites are great and they are bright even in bright sunlight!See you at XSEast
          2005 Honda SilverWing 600
          2018 Honda PC-Xpress 150
