Performance
  • tiredoffixing
    • Mar 2008
    • 89
    • Ohio
    Performance
    DOES ANYONE KNOW ABOUT WHAT THE XS WILL DO IN THE 1/4 MILE? i HAVE A 81 XS 1100S i HAVE A 4 INTO1 AND PODS. OTHER THAN THAT ITS PRETTY STOCK,EXCEPT FOR THE CARBS BEING REJETTED. THANKS
  • egsols
    • Jan 2006
    • 1090
    • Barrie, Ontario, Canada
    Somewhere around 11?
    Ernie
    • tiredoffixing
      • Mar 2008
      • 89
      • Ohio
      HIGH 11'S OR LOW 11'S?
      • BrianB
        • 362
        • Idaho
        Depends on the rider.
        1980 XS Eleven Special
        • tiredoffixing
          • Mar 2008
          • 89
          • Ohio
          IS IT POSSABLE TO GO UNDER 11?
          • egsols
            • Jan 2006
            • 1090
            And the age thereof!
            It's funny how my SF feels so much faster now than it did 20 years ago!
            Ernie
            • egsols
              • Jan 2006
              • 1090
              I think the specials were rated in the high 11's but thought I read somewhere that in 79 they had acheived high 10's (not sure)
              Ernie
              • mro
                • 4276
                • Hayward, California
                stockers
                78's would do 11's with an XSperienced rider.
                79's should be very close to same.
                80's+ most likely 13's and maybe a little better with a jockey like operator.
                On a modified XS (the hot rod XS) PO said it turned 10.4 in the quarter
                Personally not into tracks or drag strips. Was "practicing" starts on the street in front of my shop awhile back and doing some wheelies in first and second...wound up cracking the clutch basket . The hot rod (after pulling the carbs several times and adjusting floats, trial/error) has a lot more power than a stocker.
                mro
                  • 7830
                  The '81 SHOULD be able to do about a 12.5 in the 1/4, if you are about 170 pounds. The '78 would do 11.8 to 11.9 with almost anybody on it, back in '78. The fuel is different today, and the range AND performance suffers because of it.
                  • tiredoffixing
                    • Mar 2008
                    • 89
                    • Ohio
                    THANKS FOR ALL YOU ANSWERS. THIS IS A GREAT WEB SITE!!!!
                    • Shawnb
                      • Jun 2008
                      • 88
                        Once again ShawnB posts the unintelligible...
                        Hey, tiredoffixing... you might want to take the cap locks off on your keyboard. In a forum, all caps looks like you are screaming everything and it's a bit annoying.
                        Just a suggestion.
                          Easy my friend...
                            • 2088
                            Back in 1987 my friend who owned a dealership in NJ took my SG and his 79(i believe it was a SF) up to a drag strip by where i live.He told me both bikes turn mid 10's but fell to a Suzuki GS1150 set up for the strip.Mind you this was back in 87 and my friend at that time couldn't have weighed more than 160lbs.Depends on the rider.
