Front end shimy
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    I finally got around to bleeding my front brakes and that has seem to fix my shimy problem. Thanks guys.
    BDF Special
    • blue giant
      • Aug 2007
      • 880
      • Ontario, Canada
      That's good news James.
      Do you think you may have had air or maybe water in one caliper?
      Paul
      Paul
      1983 XJ1100 Maxim
      1979 XS1100 Standard
      1980 XS1100 Special
      I'm not a motorcycle mechanic but I play one on the internet.
      • Flatlander
        • 288
        • Michigan, Thumb
        Would someone care to exlpain how air/water/bleeding could lead to a shimmy or a fix?
        I had the same problem and it ended up being the master cylinder.
        I had thought that it was a sticky caliper for the longest time. Also thought that I had fixed the caliper, until the problem had returned later. What I found is that the master cylinder was sticking from time to time and by removing the calipers and working them, I was freeing up the master cylinder for a little while.
        What I did to fix my problem (not recommended, but worked) was, dissamble the master cylinder and I took a wire brush pipe fitting cleaner, one size larger than the cylinder and I don't remember what size. Gave it a one turn in until it bottomed out and in the same direction, turned and pulled it back out. Just once is all it took. Cleaned it really well with brake cleaner and compressed air. No problems since. I'm telling this story incase your problem returns.
        Hope it don't, and good luck.
        Flatlander
        '81 XS11H
        • tinman905
          • Aug 2007
          • 946
          There was alot of air in it. Many air bubbles came out when I did the right side the left was fine. Next time I will take my time when bleeding the brakes , the air takes a bit longer to flow through the lines than I thought.
          BDF Special
          • blue giant
            • Aug 2007
            • 880
            • Ontario, Canada
            I think Tinman just did!
            Paul
            1983 XJ1100 Maxim
            1980 XS1100 Special
            • Flatlander
              • 288
              • Michigan, Thumb
              I hope the problem dosen't return, is what I meant to say.
              Flatlander
              '81 XS11H
              • blue giant
                • Aug 2007
                • 880
                • Ontario, Canada
                I was just being a wise ass!
                Paul
                1983 XJ1100 Maxim
                1980 XS1100 Special
                • Flatlander
                  • 288
                  • Michigan, Thumb
                  O.K. Smarty, My turn, (refering to blue giant)
                  Explain how the air in the line makes a front wheel shimmy then.
                  Just kiddding around too, but I'm also trying to understand how this shimmy would happen.
                  It's got me baffeled and in persuit of understanding.
                  Flatlander
                  '81 XS11H
                    That one is easy!!!
                    You had the air in ONE caliper, and it was NOT working with the same pressure as the other. You start to get a grab on the one, and the second is just touching, with a rotor just SLIGHTLY out of round, and you have a wiggle.
                    I know, this was for blue giant, but I couldn't resist!
                    • Flatlander
                      • 288
                      • Michigan, Thumb
                      I LIKE IT!!!
                      That one is easy!!!
                      Genious!!!
                      Flatlander
                      '81 XS11H
                      • blue giant
                        • Aug 2007
                        • 880
                        • Ontario, Canada
                        Yup!
                        Ray said it best!
                        Paul
                        1983 XJ1100 Maxim
                        1980 XS1100 Special
