Thank you, my Leige
I think you're right, but as confused as I've sounded in the threads til now, I don't want to be wrong again.
I will get this bike running, one way or the other. It's becoming a matter of pride for me. Especially since I believe I have a sabotuer(sp)in my midst, knowingly or otherwise, and I will not be denied-Wow-was that me?-. I want this thing running by the end of the month and will see that it happens.
I can, and will, lap the head and get it put back on-without the help that is extended to me here at home. I have all I need to do this. The 79 head may add some juice due to the tighter clearances. Somehow, I may-no, will-have enough energy left tomorrow to check the valves on the 79 and go from there.
Luckily, before I tear it apart, I will be here to see what you think. Stick with me, you'll be impressed!
DO you still have the carbs off?? If not, if it's not too much trouble, take them off, and the intake boots, and look inside the head at the valves. Rotate the engine so that you can see the valves going down and up, and see if you can see a ring of buildup below where the valves go up into the head at the valve guides while looking into the intake chamber? If you see a lot of crud around the valve stem near the valve head along with a clean zone when the valve is sticking DOWN in the open position, then you might be able to get some strong carb cleaner to spritz in there along with a fine brush to break up, dissolve the carbon to see if it will allow the valve to retract farther up into the head when the cam releases it!? Then recheck the clearance. IF the clearance gets smaller, then you/we may be on to something, and you may be able to get compression without pulling the head off!?
Putting a jack under the engine and lifting it a little could have helped you put the bolts back in!
These machine do have plenty of power/torque in the low rpms, but they like to be run as well, I rarely shift under 5K rpm, often take it to 7+ during accel ramp runs and such! Also frequent use of SeaFoam or similar can help keep things cleaned out!
[/IMG]
[/IMG] [IMG]
[/IMG] [IMG]
[/IMG] [IMG]
[/IMG] [IMG]
[/IMG]
