If you're replacing your cam chain with a new one with a rivetable link, make sure you're on that lower sprocket and your dots are pointing where they're supposed to before you crimp the rivets! I had mine all setup (apparently) with the cams in their correct orientation and the timing plate pointing at "T". Crimped the link and went to turn the crank back and forth a little by hand to make sure the orientation stayed that way. Turned the crank and nothing moved on top - expletive deleted! Somehow in my fiddleing around I had managed to get the chain off the crank sprocket.
In retrospect, what I should have done is to put the link in place, hold it together with my left hand while moving the crank with my right to double check the setup. Would have saved me the five days I now have to wait for a rivetable link to arrive by mail.
The point was don't be in a big hurry to rivet that link.
Same for JB Weld.
This time it just made the mercury along with whatever was in it get uncomfortably high in the tubes. Then I started to take it apart, and that was all she wrote. Properly damped vacuum gauges seem to work better anyway, and I don't have a toxic chemical hanging on the wall in the garage anymore.
