front wheel bearing spacer?
  • jurgenkoppen
    • Jul 2007
    • 97
    • Powell River, BC Canada
    Hi,
    I am wondering if anybody has the spacer which belongs between the front wheel bearings?
    I looked but never did see one on Ebay, I guess because as a rule the spacer is so well contained and nobody seems to disassemble their hub.
    Anyway, one of my restore projects came with a wobbling front axle, and that was because the spacer was missing, and one bearing consequently packed it in.
    If you have the spacer, I could use a bearing as well.....
    Jurgen
    80 1100SG with 79 engine
    79 1100F being restored
    78 xs650 runabout (mpg, eh?)
    Irreverence is the champion of liberty and its only sure defense
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    You can buy the spacer and bearing from this site. Yamaha Parts Hit OEM, then enter your model and year. The spacer is 5 or 6 bucks. The bearings are 15 or 20 bucks. Or you can wait to see if used ones show up on ebay... Not sure I'd buy used bearings though. Good luck!
    Tim
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
