Another question re: oil leak
  • newmaac
    • Dec 2002
    • 369
    • San Jose, CA
    I'd like to get some input regarding the valve cover gasket.
    Several years ago, when I first removed the valve cover to check and adjust valves, I found the gasket to be in good shape. I had a little seepage at the half moon cam plugs, so I replaced those, but left the old gasket intact.
    I had the cover off several times before I actually damaged the gasket and had to replace it.
    Now, with a new gasket, the thing leaks pretty badly. Not just in any one area, but several.
    I am using an OEM gasket bought from the dealer, using a gasket sealer to bond the gasket to the cover, but not to the head itself.
    That is how I found it, and it always seemed to work before.
    I know that I could use sealer to seal the gasket to the head. That would solve my problem today, but I would be "hating it" the next time that I had to get the cover off.
    So, what's the general consencious?
    Do you folks dry-set the gasket to the head?
    TIA,
    Mike
    1980 SG "Angus"
    gasket
    I spray the gasket with Pam cooking spray only. This helps for removal next time. I use a bead of RTV black on the half-moons. Make sure both of your gasket surfaces are clean and you shouldn't have a problem. Tightening sequence mabye?
    • mro
      • 4276
      • Hayward, California
      I don't care much for the hassle of putting sealant on the valve cover. Takes forever cleaning that cra... stuff off.
      On the G had constant leaks and had to clean it ever 400/500 miles. Last time I had the cover off, gasket was still in good condition...so cleaned it and put a second (doubled) gasket on it.
      Leaked no more
      mro
